Diodes / Snubbers?
revolver1
Diodes / Snubbers?
Post by revolver1 » Wed Oct 25, 2017 4:42 am
revolver1
Re: Diodes / Snubbers?
Post by revolver1 » Wed Oct 25, 2017 4:46 am
I have seen so many different versions on a theme and have gotten quite confused.
Could someone with a little more knowledge please tell me if this is correct or not? Or if it could be improved in any way??? :what:
revolver1
Post by revolver1 » Thu Oct 26, 2017 4:36 am
revolver1
Post by revolver1 » Thu Oct 26, 2017 4:48 am
I'm looking at gut shots but it can be slightly tricky to follow the wiring. Is the above correct for 68/69 period? Whats the snubber value? I dont think its .22uf?
revolver1
Post by revolver1 » Thu Oct 26, 2017 4:57 am
The 68/69 version looks really interesting, I'd like to try this in the future.
For this build the more I look at it I'm really building more of a 70/71 amp. I had already staked the board for two snubbers and cutting it back could be risky. Plus I'd already cut a hole on top for the preamp filter and the switches I ordered are DP/DT.
Just need to know if I'm doing it right as in the first diagram. I've tried to figure it out but It's hard to be 100% sure from photographs, the only lay outs I've seen with snubbers is the 100watt and that's a slightly different rectifier set up. I've got no 50watt lay outs with 2 snubbers to reference.
revolver1
Post by revolver1 » Tue Oct 31, 2017 3:06 am
Anyone?
Connection 10 - 11 is that right? Snubbers to ground??
And is it from 16 - 17 or 16 - 19? Diodes to fuse carrier or diodes to mains filter??
revolver1
Post by revolver1 » Thu Nov 02, 2017 3:10 am
Bump?
Post by neikeel » Thu Nov 02, 2017 7:18 pm
Use this schem and apply to your layout:
http://drtube.com/schematics/marshall/1987u.gif
Only take bias feed from hot side (PT HT) of the standby switch
revolver1
Post by revolver1 » Sun Nov 05, 2017 4:16 am
Thanks neikeel I think I've got it.
I need to go from diodes to filter can to fuse to O.T /choke.
