Hey again all,
Once again reaching out for your expertise here regarding a discrepancy I am seeing doing this build:
The chassis is marked for a 2A Mains fuse and the schematic shows this too, but the directions specify a 3A fuse in the"Testing Part One - Step A" section, the parts list section, and the schematic on page 32.
what gives? i just put the board in the chassis so still have much wiring/soldering to do before it's an issue but thought i'd get the ball rolling now
thanks in advance,
Stu
which MAINS fuse for MetroAmp 50 Watt kit? directions conflict
Re: which MAINS fuse for MetroAmp 50 Watt kit? directions conflict
3Amp fuse for 120Vac; 2Amp for 230-240Vac.
Ok thank you!
maybe that's where the confusion in the directions is
Regards,
Stu
Regards,
Stu
