Almost no output
Lordhumongous
Almost no output
Post by Lordhumongous » Sun Mar 03, 2019 5:51 pm
Hello all! Just finished up my metro spec 1987. Sourced all the parts from valvestorm except a transformer set from classictone. Let me begin by saying I am NOT an amp tech. I just want to rock. I can follow directions however and sought to build one of my dream amps I couldn't otherwise afford. That being said, after start up, amp has almost no volume. Does emit a sad volume while turned all the way up. Eq and presence controls all function properly as well as bright channel is bright, normal channel is darker as one would expect. Does this sound familiar? Hoping someone can counsel me through this. Thank you :rockon:
stryker59
Re: Almost no output
Post by stryker59 » Sun Mar 10, 2019 1:29 pm
Check the 470 ohm resistor between the 1m pair at the phase inverter and make sure you didn't use 470k ohm
Post by neikeel » Tue Mar 12, 2019 8:14 am
Typical one is 470k cathode resistor on PI instead of 470R
Look and measure between the two 1M resistors on the board.
danman
Post by danman » Tue Mar 12, 2019 7:23 pm
Yep...Neikeel has the answer! Most likely a 470k between the two 1m resistors in the middle of the board instead of the correct 470 ohm. Happens quite a bit in new builds unless you measure every resistor before installing.
Post by neikeel » Sun Mar 17, 2019 12:39 pm
:what:
danman
Post by danman » Sun Mar 17, 2019 6:48 pm
He must have got it sorted out and playing right :rock:
axeman
Post by axeman » Mon Mar 18, 2019 12:55 am
He probably crossed the the green wire for V1? Not sure have to see.
