Choke Size
- Guitar Adjuster
Choke Size
What would be the correct choke size for a 50 watt 73'ish plexi?
- Bluesgeetar
hmm
Ask Brian Wallace.
- Guitar Adjuster
George is doing a Metro choke clone of a 352-114 (U shaped frame) which I think is the same spec as the 50/100 watters (5H) not sure of the current rating. There is a C1999 choke like this, not sure of its value (Mighty Mike might know)
I am going to put one of Georges in my new build 50 watter.
I have a NMV 50 watter with a 2.2H (bell cover type, 1976) and 3H (open frame, 1969) in another, both, I believe both are original equipment.
- Brian Wallace
- Supporting Advertiser
Chokes
All the chokes mentioned are 3H. They have a tolerance just like anything else and will vary but the original factory spec is 3H. End of story.
- Guitar Adjuster
- Flames1950
Re: Chokes
We just need a new section to the forum at this rate: "Choke Talk!! with special guest Brian Wallace."Brian Wallace wrote:All the chokes mentioned are 3H. They have a tolerance just like anything else and will vary but the original factory spec is 3H. End of story.
- Brian Wallace
Answer
I just spend too much time with amps and test equipment.
The best part is, you never know it all.
Re: Choke Size
You can't say like this. Value of choke can't be correct. The larger L value, better supply voltage filtering for circuits following final stage (inverter, preamp).Guitar Adjuster wrote:What would be the correct choke size for a 50 watt 73'ish plexi?
It is not used before final stage, because OT primary inductance compensate it. And OT primary L is much larger, than choke L.
It could be said, that larger L provide better filtering and it needs especially 1st preamp stage with high gain. You can left choke. Amp will be functional, but you can hear more unfiltered hum or noise. Everything has pros and cons.
