Amp layouts, courtesy of BillyBatz
The first 69' 19959 layout I did was time consuming. Since then its just been modifying that one graphic and many times I did it fast. I dont think theres many actual electonic mistakes but there are deviations from the way marrshall layed out things. If you havent noticed already the first reply on this thread on page 1 is a log of mistakes fixed, mistakes left to fix and when the last update was. You may want to check that out.
- MacGaden
- Wiki Editor
Early 2203
Hi everyone. I've been lurking for a bit. Great forum!
Question about the 2203 layout. Does yours refelect the MV which used the 6550 Power Tubes or the EL34?
Theyre the same amp as far as I know. There may be a change in the value of the bias pot resistor. I dont think you would change anything else though. 1K screen-grids I think with 6550's as well. Maybe the OTs int hose amps were made for 6550s? Different impedance? Even if that is the case people use 6550's with these amps even though the OTs are for EL34s.
- wdelaney72
According to Dave at Legendary Tones, Marshall used the 6550 for US MV because they were more durable, and EL34 for the rest of the world. I would guess it would have only been cost effective to do so if the rest of the components were the same. I'm sure the bias would have to be adjusted, though.
Thanks for your help.
- Flames1950
The 6550 amps got not only a bias resistor change at the distributor, but also got 150K splitters instead of 220K's. (Actually I think the official way at the distributors had two resistors that changed -- the one before the bias diode changed as well.....)Billy Batz wrote:Theyre the same amp as far as I know. There may be a change in the value of the bias pot resistor. I dont think you would change anything else though. 1K screen-grids I think with 6550's as well. Maybe the OTs int hose amps were made for 6550s? Different impedance? Even if that is the case people use 6550's with these amps even though the OTs are for EL34s.
- wdelaney72
Found this on Clay Finley's site...
"Also the 70's Marshalls saw different bias splitter values. 82K, 100K, 150K and the common 220K. The smaller values will load down the preamp and roll off the top end. The 82K/100K was usually used when 6550's came stock in the amp. A lot of people had the 6550's switched over to EL34's and most techs didn't change the bias splitters which resulted in a little more preamp crunch and a "browner" sound to the top end. The 220K's are the classic value for use with EL34's."
