Your the man Billy, thank bro!!!!!!Billy Batz wrote:no. More high end less gain. 270k has less resistance between the mixer and the unused/opposite channels volume pot ground. In other words the volume controls are more interactive with each other.
Clay Finley's document which is posted in another thread references dating by 470K mixer resistor.Billy Batz wrote:I read an article somewhere specifically about those mixer resistors. It said you can date marshalls by the presence of 470k mixers because they started in early 67. If the amp has 270k that doesnt mean its pre 67 because they still showed up in amps after the 470k's but the 470k's started being used at a specific ttime.
Because my layout is made for both the earlier 67 style amps with the 2" OPTs and the later 67 and 68 amps (12 series). The vast majority would have 2 resistors or at least space for 2 resistors (one may be bypassed by a jumper wire.) The resistors only add together for a higher resistance. Nothing special but the early 67 amps with 2" OTs probably would mostly have the single resistor there. In fact I just use one myself. I can buy a 5W or 7W 18.4k or 20k but I mostly just use 10k there.Metal Handles wrote:1- just to the left of the first 10uf can George has a single 8.2K resistor. Billy and Dan's layouts both show dual 10k and 8.2k. Which is preferred and why?
[/quote]2-do I connect the negative feedback wire (from the 8 ohm tab on the ohm selector switch) to one end of the 27k resistor that the other end connects to the right tab of the presence pot?
