Page 1 of 2
'67 100 watt board layout
Posted: Thu Aug 11, 2005 4:53 pm
by VelvetGeorge
With all of the interest in earlier 100 watts lately, I thought a diagram might help. This is the circuit and layout in my '67.
Posted: Thu Aug 11, 2005 4:55 pm
by VelvetGeorge
Here's a smaller copy of the jpg.
Posted: Thu Aug 11, 2005 9:35 pm
by gnugear
Is that 68k in parallel with the 10uf normal?
Posted: Fri Aug 12, 2005 12:32 am
by 7string
Thank You for the layout George.
Thats gonna help me bigtime.
Pat
Posted: Fri Aug 12, 2005 12:33 am
by bmf5150
thats for biasing correct?
stan
Posted: Fri Aug 12, 2005 12:35 am
by 5150loveeddie
I though the mix resistors were 270K in 67?
Posted: Fri Aug 12, 2005 12:40 am
by VelvetGeorge
The 68k is for biasing.
My late '67 has 470k mix resistors, but they should be 270k earlier in '67.
Posted: Fri Aug 12, 2005 2:51 pm
by mightymike
Thanks George.
Posted: Fri Aug 12, 2005 6:14 pm
by Ralle 500
5150loveeddie wrote:I though the mix resistors were 270K in 67?
Those were in the JTM's
Ralle
Posted: Fri Aug 12, 2005 8:45 pm
by Guest
George,
You sure you don't have a 10k/1watt resistor in series with that 8k2/1watt resistor on the H.T. line? I know the earlier '67 amps had just the one 8k2 resistor, but I thought your amp was a slighly later '67 amp.
Posted: Sat Aug 13, 2005 1:20 am
by 5150loveeddie
Ralle 500 wrote:5150loveeddie wrote:I though the mix resistors were 270K in 67?
Ralle
Yeah?
Posted: Sat Aug 13, 2005 3:55 pm
by Billy Batz
I read an article somewhere specifically about those mixer resistors. It said you can date marshalls by the presence of 470k mixers because they started in early 67. If the amp has 270k that doesnt mean its pre 67 because they still showed up in amps after the 470k's but the 470k's started being used at a specific ttime.
Posted: Sat Aug 13, 2005 3:58 pm
by Flames1950
I remember that too but I don't remember where I read it.
Posted: Sat Aug 13, 2005 4:20 pm
by 5150loveeddie
What would be the differences between the 270ks and the 470ks? Anyone knows, more gain with the 270Ks mix resistors??
Posted: Sat Aug 13, 2005 4:24 pm
by Billy Batz
no. More high end less gain. 270k has less resistance between the mixer and the unused/opposite channels volume pot ground. In other words the volume controls are more interactive with each other.
