68 12xxx Channels
axeman
68 12xxx Channels
Post by axeman » Fri Oct 03, 2008 8:02 am
Hi Guys. Are channel 1 and 2 in a 68 interactable with each other without a patch cable?
Are they internally bridged?
Axeman
Re: 68 12xxx Channels
Post by Flames1950 » Fri Oct 03, 2008 8:58 pm
The channels are interactive, but it's through the way they mix together -- it's not the same as being bridged with a patch cable. You'll hear some differences in gain and tone as you turn the unused volume control up and down.
axeman
Post by axeman » Sat Oct 04, 2008 1:33 am
I am not able to bridge them together. They interact with each other allready.
Post by neikeel » Sat Oct 04, 2008 5:10 am
Did you build it?
If not do you have a good picture of how it is wired.
It is certainly possible to bridge internally but don't understand why you should need to- it takes some of the flexibility away...............
axeman
Post by axeman » Sat Oct 04, 2008 3:13 pm
I used the BillyBatz Layout
