Can 100 W Plexi Kit Be Tweaked to be "All Clean"?
yZe
Post by yZe » Mon Nov 03, 2008 2:27 pm
I am looking for those deep Marshall cleans w/ no breakup at high volumes
Does the Bass Plexi or Superlead kit allow for more headroom ?
How can the amp kit be tweaked at the onset in order to allow for high headroom cleans at stage volumes?
Re: Can 100 W Plexi Kit Be Tweaked to be "All Clean"?
Post by VelvetGeorge » Mon Nov 03, 2008 2:33 pm
Sure, to a degree.
I would try Bass specs with 12AT7's in the V2 and V3 positions. V1 if you can find one that isn't noisy there.
Also look at PA specs which are 99% the same. Generally no cap on the mixer resistors.
You can also increase the negative feedback in the output section.
VG
yZe
Post by yZe » Mon Nov 03, 2008 2:52 pm
thanks for the quick reply
How would "no cap on the mixer resistors" for a PA system translate into the amp build?
Where would there be no caps on the plexi circuit?
Does increasing the values on the grid & screen resistors help toward headroom?
Would that mod affect the tone adversely ?
Mars Hall
Post by Mars Hall » Mon Nov 03, 2008 3:32 pm
6550 output tubes will also improve headroom. IMO the EL34 output tubes do not lend themselves toward a "clean" tone.
yZe
Post by yZe » Mon Nov 03, 2008 3:51 pm
What does the power transformer have to be rated at to hande 6550's w/o melting down ?
Also,, are there mods that have to be done to handle the 6550's?
Mars Hall
Post by Mars Hall » Tue Nov 04, 2008 1:06 pm
I'm not an expert on transformers. It should work fine. The only thing to change are bias circuit resistors to set the voltage range.
Roe
Post by Roe » Tue Nov 04, 2008 1:26 pm
get a 69 superbass kit (or a 45/100), change the 220k bias resistors to 150ks or 100ks, skip the 500pf mixer bypass resistor, and install new genalex kt88s, a 12at7 in v3, a 5751 in v2 and v1 (or try a 12au7 in v1 like the tweed amps)
also, try a 27k nfb resistor connected to the 16 ohm output (jtm specs) instead of the standard 47k
908ssp
Post by 908ssp » Wed Nov 05, 2008 10:03 am
And don't turn your guitar volume up all the way. :wink:
