thanks SDM.SDM wrote:To Budubum,
Since you've got a PCB replacement board in a RI, take a look at the pic below, let me know the space you have there from board to chassis, and resonance pot to chassis. Some ideas on how it'd could hook up, it'll be tight, but has worked out fine in similar RoccO'cconor modded amps. You may want/need to also rotate the resonance control so the pot's lugs/cap are pointing away from the loop board, but that may not be needed.
ok i measured the amp soon as i saw your post.
heres it:
from far left of V1 to the round curve of the resonance pot`s cap lead is ca. 12cm
from heater wall to teh board is ca. 5 cm.
the deepness of the chassis from TOP to bottom of chassis where the sockets are mounted to the chasiss is ca. 6½ cm
i know eaxactly where/how to put the b+ wire now. want it under the board then throught that little hole and up to the alternate B+ point on the preamp like youve circled.
sorry for using CM rather than inches as we dont measure inches in Sweden therefore we do metric.
thanks in advance.
