Mxzx wrote:Help, I just installed this loop in a 1987 clone and lost all input signal. Doesn't matter if switch is on or off.
The amp has both a PPIMV and the one wire mod.
Thanks in advance!
The bypass switch bypasses the loop entirely, so something is miswired, shorted, or perhaps was disrupted elsewhere in the amp. Small chance the switch is bad all around, but possible.
If it is loop install related, most likely is a miswiring of the switch or a short of the wires to it. Triple check all wires go where they are supposed to (on BOTH ends), and the little jumper on the switch is there. Check your shielded wires, be sure the shields are not shorting out to the inner conductor wire <- this is a common error and shorts the signal right to ground. Even a tiny stray strand of the shield can muck things up here, look close at the switch end in particular. If you nicked a shielded wire with an iron or such elsewhere (or even if you didn't), it may be shorted internally. Measure the (inner) wires of the shielded wires to ground, neither should be anywhere near shorted in any switch position.
If not the above, can check the switch by setting it to bypass and shorting the two middle lugs together (the lugs with the shielded wires on them). Use a small bit of wire or whatever, just a temporary test here. If still no signal, go check the above yet again. Nothing amiss, something elsewhere in the amp was disturbed during the loop install.
