I just fired up a new Metropoulos 1969 Superlead build, and I'm getting low voltage readings:
pre- and power-amp heaters read 3.0 VAC (not too far from 3.25)
Power amp pin 5 reads -30 VDC (good)
Power amps pins 3, 4, & 6 read 235 VDC (way too low).
Any idea what's causing those low readings on the power amp sockets?
thanks in advance...
Low voltage readings on new build
- Flames1950
Thanks for the tip!Flames1950 wrote:Best to set that bias voltage at pin 5 of each power tube socket lower than -30 before firing it up with tubes!!! Adjust the bias voltage to as large a negative value as you can get (-50VDC maybe??) to ensure that your tubes will be running cold at first, as opposed to smoking hot.
The one thing I left out was that I had my first experience with a discharging cap. I decided to bridge the two terminals (amp unplugged, of course) with a piece of wire, and as I'm lining the wire up with the terminals -- thankfully gripped with insulated pliers -- a get a loud zap and a bright spark, followed by a rapid heart beat and lots of cursing.
I had checked to make sure that the filter caps were drained, but I never checked that one...
