Is this correct?
The blue wires on the left are from the OT.
I want it so the high voltage switch position is towards the power switch.
I left it out, but I believe the white bias wire will go to pin 2 of the switch.
I thought I saw a picture of this recently on the site but couldn't find it. If I recall correctly I saw a variable resistor instead of the fixed one on it. I do have two variables with my kit. Is this is for adjusting the bias separately for the two voltages?
