HEY GEORGE!!Cool idea that just might work! ANY THOUGHTS??
ACDCG400
Post by ACDCG400 » Mon Aug 06, 2007 7:01 pm
hey guys can i buy a volt meter
https://taweber.powweb.com/store/am1000VDC.jpg
https://taweber.powweb.com/store/meterord.htm
and hook it up in series with the B+ on the tube or on the standby and measure volts from when i have on the high and low voltage setting?
can this also be applied with a watt meter between the output and the load?
what do you think?
The mark of a good amp is that even when your fingers ain't cookin', your amp is. -Malcolm young
Where is the "balls" control? AH! here it is. why'd they label it volume?
