JTM45RI to JMP50?
JTM45RI to JMP50?
I have a JTM45RI that has the usual mods. Marstran trannys, PTP board, etc. While it sounds very good I don't play it much. I usually use my Fender Deluxes. I got to play a 70' 50 watter I used to own a few days ago and really have GAS for a plexi 50. I thinking of converting my JTM45RI. Bad Idea? Should I just save up and buy a 50 watt kit?
- jerrydyer
there are some mods you can do to switch between your tube rectifier and a solid state diode chain like the 50's I wouldnt completely take away the tube rectifier. Its good for certain things.
vids.
