Bass or Lead Spec?
Ag_Nathus
Bass or Lead Spec?
Post by Ag_Nathus » Thu Oct 23, 2008 6:44 pm
One more quick question before ordering. How different are the 100 watt lead and bass kits from a sound standpoint? I was just curious if I could get some opinions on which one I would be better off getting. I really enjoy The Song Remains the Same kind of tone for my Les Paul and the Woodstock sound for my Strat and home-made Fuzz Face. Which build would probably get me closer or should I just order the extra parts and try them both out. And, if so, what are the extra parts between the two? (jeez, I don't want much, do I?)
Thanks for the help!
AG
Gaetano
Re: Bass or Lead Spec?
Post by Gaetano » Fri Oct 24, 2008 9:33 am
Well, let's go...
If you want to play with a les paul and get pages tones, you need a SL build with 5000 pf bright cap.
For strat-players i prefer superbass builds, as the guitar itself is bright sounding.
A good compromise would be a SL build without the bright cap or with a low-value one.
You should be able to build the amp in lead or bass specs with the same kit, they should contain all the parts FWIK.
Bring your fair maidens out, for the vikings are coming to pillage. (Robert Plant)
'71 SB to SL
'82 1960a - G12-65
Ag_Nathus
Post by Ag_Nathus » Fri Oct 24, 2008 3:34 pm
Thanks for the reply. While I had gotten the impression in other posts that the kit could be built either way, when I looked on the online store it asks for you to select lead or bass, so maybe I will just need to buy some extra parts. Is there an easy way to know what they are without cross-referencing the BOMs? This is for the stock 100 watt plexi style kit, by the way!
Thanks again!
Ag
Post by VelvetGeorge » Fri Oct 24, 2008 3:36 pm
I just added the Lead or Bass specs option. This is only for the signal cap values that we include with the kit. The extra resistor and silver mica values are already included with every kit.
If you want the extra parts to try both circuits, you could just select the lead option, and add:
(2) .1uf 400V signal caps.
Ag_Nathus
Post by Ag_Nathus » Fri Oct 24, 2008 5:23 pm
VelvetGeorge wrote:I just added the Lead or Bass specs option. This is only for the signal cap values that we include with the kit. The extra resistor and silver mica values are already included with every kit.
Nice! That is exactly what I am going to do! Thank you sir!
AG
Gaetano
Post by Gaetano » Sat Oct 25, 2008 4:20 am
Good luck! :mrgreen:
'71 SB to SL
'82 1960a - G12-65
Bunnest
Post by Bunnest » Fri Oct 31, 2008 12:33 pm
start with the 2 .1 output couplers, I always prefer that spec with lead or bass, then try the different tone stack, then try splitting the v1 cathode. You may stop somewhere in between!! 8)
68 Marshall JMP 100 Plexi
69 Marshall JMP 100 Plexi
71 Marshall JMP 100 Metalface
66 BF Fender Pro Reverb
67 BF Fender Super Reverb
