Thanks,
Dennis.
Well..... I have magnetic components trannies and choke laying around....neikeel wrote:First questio I would ask is what trannies you have?
http://forum.metroamp.com/viewtopic.php?f=22&t=6599
I have a clone with 1202-43 (KT66s) set up as 45/100
http://s76.photobucket.com/albums/j2/ne ... res038.jpg,
an original '67 with 1202-119 using stock filtering, dual rectifiers and EL34s
http://s76.photobucket.com/albums/j2/ne ... Superlead/,
I also have a Black Flag clone I built with 1202-132
http://s76.photobucket.com/albums/j2/ne ... ck%20Flag/.
The boards on these are very similar (the KT66 amp only has 22uF x2 in preamp and 270k mixer resistors) with shared cathode on V1 and 56k/250pF tone stack with 0.1uF PI couplers. The KT66 amp has 27k on 16ohm NFB, the first EL34 27k on 8ohm and the -132 amp 47k on 8ohm.
I used the -132 for the latter as it is still 2" core but is for EL34s and has 4/8 and 16 ohm taps. In this amp I used 50uF mains filtering (x4 47uF in series parallel), 22uF screens (47uF x2 in series) and 22uF PI (47uF x2 in series) and 32uF+32uF in preamp.
The later 10 series filtering is the same as my 68SL
but the same preamp as the early amps (ie SB) as Roe says filtering on these is 50mains, 16screens, 48PI (at least mine is) and 32/32 preamp.
Long and short is, I have done my research!
I would build a -132 OT with EL34s and 50uF mains, 22uF screens, 22uF PI and a -114 choke, stock 1203-80PT and 47k on the 8ohm tap NFB.
Keep us posted
Which ones?wildebassman wrote:Well..... I have magnetic components trannies and choke laying around....
Cheers,
dennis.
What are they equivalent to?wildebassman wrote:Neil,
I have: 40-18026 OT,40-18024 PT, and 40-18032 5H choke.
Cheers,
Dennis.
