Superbass V1 Cathode Capacitor value
ThunderOne
Post by ThunderOne » Wed Mar 03, 2010 9:59 am
Has someone tried changing the 330uf V1 cap on a Superbass to 250uf while leaving everything else stock? Would it tighten the low end noticeably? I figured that the difference between the two would be insignificant but I would appreciate your thoughts on this.
Franz
Re: Superbass V1 Cathode Capacitor value
Post by neikeel » Wed Mar 03, 2010 11:15 am
ThunderOne wrote:Has someone tried changing the 330uf V1 cap on a Superbass to 250uf while leaving everything else stock? Would it tighten the low end noticeably? I figured that the difference between the two would be insignificant but I would appreciate your thoughts on this.
Virtually no audible difference in these cap sizes there. You need to decrease to <10uF (some would say lower :wink: ) to notice.
ThunderOne
Post by ThunderOne » Wed Mar 03, 2010 1:24 pm
Thanks for your input, Neil!
Franz
Post by Roe » Wed Mar 03, 2010 2:20 pm
a 250uf cap can easily measure 330uf :wink:
ThunderOne
Post by ThunderOne » Wed Mar 03, 2010 2:37 pm
Roe wrote:a 250uf cap can easily measure 330uf :wink:
Damn, you're right! I completely forgot about the tolerance thing! :)
Franz
Post by Roe » Wed Mar 03, 2010 3:29 pm
people are very specific about their electrolytic caps but tend to forget that the old caps varied a lot, often from -10% to +90% on the bigger caps
54strat
Post by 54strat » Wed Mar 03, 2010 5:35 pm
You guys have me thinking about changing my V-1 cap to a 10uF. I changed my Lead amp to Bass specs and love it except for the fact that I can't run the Bass pot up past 2 or 3. I don't want to lose any beef but would like to keep it from woofing out.
73 Marshall 1987
87 Fender Stratocaster
Post by Roe » Wed Mar 03, 2010 5:57 pm
10uf will loose beef. try to decrease the v1 coupling cap instead. try .01 or even .0047
