Bright Channel Volume
On my 100W kit, when I plug into my bright channel inputs, I can clearly hear the guitar coming through the speakers even though the volume knob on the amp is at zero. Is that normal?
Re: Bright Channel Volume
yes but it shouldn't be loud
Seriously, how often doo yyou play with the volome set to zero
This symptom is normal layout related (= crosstalk).
Regards
Robert
Regards
Robert
- flemingmras
Happens more on the bright channel due to the bright caps. If you're that concerned with it, remove the bright cap from Volume I. That should get rid of a lot of it. When Volume I is cranked that cap is useless anyway.
Robert brings up a good point though.
