Install Zero Loss Loop in 1 watt amp?
Santi_
Post by Santi_ » Sun Feb 19, 2017 6:07 pm
Hello .
I'm a newbie in diy amps and i need a little help .
i've made a jtm1 1 watt amp following this squematic .
It's a cool little amp and sound great for home use , but i miss a effect loop .
Will this loop work with this b+ Voltages?
Thank you !
SDM
Re: Install Zero Loss Loop in 1 watt amp?
Post by SDM » Thu Feb 23, 2017 4:33 am
Yeah, around 250V is fine.
AJW
Post by AJW » Mon Jul 10, 2017 4:53 pm
I know it's been a while, but if you ever added this to your amp let me know how it worked out. I built one of these in a valve junior combo. I'm not sure if I have real estate in the chassis for the Zero loss loop, but it is an interesting idea. :toast:
