dukeamps
Post by dukeamps » Tue Jun 22, 2021 3:32 am
gluke wrote:
Tue Jun 22, 2021 2:59 am
That is with the gains on 3,5 and 2.
Needs a bit of tweaking to get the bass under control.
Change the second stage to 10k .1u and the 220k on the gain pot to 150k or even 100k.
gluke
Post by gluke » Tue Jun 22, 2021 3:45 am
Will do! It will be more #34 like though?
Gluke
http://www.hugeracksinc.com" onclick="window.open(this.href);return false;
gluke
Post by gluke » Sat Jun 26, 2021 6:01 am
150k and 10k/.1 sounds like this:
WTTJ:
https://youtu.be/iWcioYVXeaM
Gluke
gluke
Post by gluke » Sat Jun 26, 2021 6:04 am
CoffeeTones wrote:
Thu Jun 17, 2021 11:32 am
If you take that MK7 topology and plop another modest gain stage in somewhere, you might find the golden egg. Many times modders follow a trend like that and I'd bet that many 80's rock records have MK7 lineage amp tones on them. I might not put a snubber on stage 1 plate since that stage is not peaked much. I'd try snubbing one of the later stages unless the stage 1 snubber is made necessary by some behavior. I doubt .68uF presence will work with the MK7 since the first stage is passing most frequencies. I may do that mod myself in a few days. There is a JCM 800 circuit just sitting here :scratch:
Here you go. Mk7 with a 10k/.1 stage and .1 presence.
WTTJ:
https://youtu.be/UvRL0YDmH8M
Nightrain:
https://youtu.be/Xj8FQe791k4
Gluke
gluke
Post by gluke » Sat Jun 26, 2021 6:06 am
Mk7 with the 10k/.1 stage between the two stages.
WTTJ:
https://youtu.be/U5vx22X_5q4
Nightrain:
https://youtu.be/3OUCdE-oajo
Gluke
dukeamps
Post by dukeamps » Sat Jun 26, 2021 9:09 am
WTTJ:
Me likey! Good job! :thumbsup:
CoffeeTones
Post by CoffeeTones » Sat Jun 26, 2021 11:21 am
WTTJ:
Nightrain:
10k // .1 placed where? NFB value?
CoffeeTones
WTTJ:
Nightrain:
10k // .1 between which two stages? NFB value?
I would try 68k to 100k NFB if you have lower. Below 68k is pretty lethargic. 10k with no .1u or 820r with no .47u. Then adjust bright caps and resistor value from gain pot wiper to ground, and retain .1u presence for now. Experiment with plate snubber location or deletion. Try the 10k stage, with or without bypass between 1 and 2 or 2 and 3, to see which you like best.
In the schemes I posted, you can read Levi's notes. He wrote that he modified JCM 800 amps, and made no mention or drawings of mods to the power section. Not saying that he never did mod the power section, just pointing out the info we have.
gluke
Post by gluke » Sat Jun 26, 2021 1:02 pm
First one is first two stages if mk7 then 10k/.1 stage
1k5/22uf/.022/470k+470p/120pf/150k
2k7/.68/.022/470k+470p/470k
10k/.1/.022
820r
100k/4ohm/.1
Gluke
gluke
Post by gluke » Sat Jun 26, 2021 2:31 pm
That one is 10k/.1 on the second stage.
1k5/22uf/.022/470k+470p/120p/150k
10k/.1/.022/470k+470p/470k
2k7/.68/.022
820r
100k/4ohm/.1
Gluke
gluke
Post by gluke » Sat Jun 26, 2021 2:34 pm
Thanx! I think I need to get a LP of some sort. SCOM just doesn’t work on a P90....
Gluke
CoffeeTones
Post by CoffeeTones » Sat Jun 26, 2021 3:34 pm
You could try increasing the 150k till the sound fills out. MK7 shows no such resistor and could possibly have no pre gain control peaker, but that might be going too far with your current spec. It sounds good, just missing a little something - that might just be in the recording.
Unique
Post by Unique » Sat Jun 26, 2021 5:22 pm
WTTJ:
This sounds pretty darn good!
gluke
Post by gluke » Sun Jun 27, 2021 10:33 am
I’ll do some more clips. We are back at the office now so I don’t have the whole house to myself all day long anymore....... coffee breaks at the home office was brilliant for small tweaks and recording clips.
Gluke
Unique
Post by Unique » Sun Jun 27, 2021 10:58 am
I'll be looking forward to them!
