25 Watt #34 2204 Clone
gldtp99
Post by gldtp99 » Wed Sep 29, 2010 8:47 am
I just did #34 mods to a 25 watt 2204 clone i built some time ago--- Heyboer 18 watt PT/OT, 4H/90mA choke, ss rec, JJ 6V6S x 2, typical near-stock 2204 preamp.
I also added a Lar/Mar PPIMV that replaced a variable NFB pot (which was of limited use).
This amp came ALIVE !!! :shock: 8) --- even with an "initial test" preamp tube set (Sovteks and a JJ) this one is producing tone similar to clips i've heard of higher wattage versions---- it doesn't have the chest thump of a 100 watter, of course, but it's a lot of fun to play.
Some differences in this amp are .015uF coupling caps on V1A&B---- V1 plate load resistors are 82k--- and the treble peaking and bright caps are removed---- the 470k/470k voltage divider is now 330k (series)/470k (ground)---- these changes were already in the amp before i did the #34 mods, no real reason to change now considering how the amp sounds.
I built a quick 50 watt turret board version of the four preamp tube AFD-type amp out of a gutted Laney AOR 50----- it also works well---i'll have to A/B these two after i get a better preamp tube set in the 25 watt #34 and do any tweaks as needed----now it's bright, a little naselly, and has great controllable feedback. And Big Balls for a 25 watter. :twisted:
Just got a new pre-punched steel JCM 800 2204-type chassis in from Watts---i wanted the aluminum blank JCM 800 chassis but they sent this one by mistake---- it's such a well-made chassis that i'll keep it and order another blank aluminum chassis for the build i was planning for it (150 watt channel switcher)------ the pre-punched steel chassis would make a great base to build a KT88x2 #34 into.
Would a #34-type amp with only two big bottles be a #17 ? If so, my 25 watter would be a #8.5................gldtp99
gldtp99
Re: 25 Watt #34 2204 Clone
Post by gldtp99 » Thu Sep 30, 2010 7:52 am
Made a few changes--- changed PI/Output coupling caps from .022 to .047---- changed Gain pot to 250kA from 1MA--- restored voltage divider to stock 470k/470k (470pF bypass).
Tested amp and removed 470pF bypass cap. better without this cap.
Tried many preamp tubes--- ended up with blackburn mullard ecc83 in V1, GE 12ax7 in V2 and V3.
Testing thru Hiwatt (Sterling) 4x12 loaded with G12T-75's----was running thru a 2x12 last night.
No more changes needed--- this is a very good sounding amp---- it amazes me how much tone/sound/impact this amp gets out of a pair of 6V6's (JJ's) and Heyboer 18 watt iron.
Frank Levi hit it right with this mod---- no wonder Slash still has the orig #34 all these years later.
I've got a Marshall 4010 50 watt JCM 800 1x12 combo that i got cheap on ebay a few yrs ago--- had been poorly modded----i restored it to stock/near stock config but this one was nothing to write home about---- tried many different speakers, etc, etc then put it into storage until i figured out what to do with it----i'll do #34 mods to this amp soon- 8) ...............gldtp99
hotguit
Post by hotguit » Sun Oct 03, 2010 5:45 am
hi
can you list the mod? the part you changed and values?
thank you
hot
LIFE IS TOO SHORT FOR A BAD TONE!!
gldtp99
Post by gldtp99 » Sun Oct 03, 2010 8:01 am
Info on this #34 mod is in the other thread concerning modding a JCM 800 to #34 specs: http://forum.metroamp.com/viewtopic.php?f=3&t=33031
If i just lay out exactly what the mod is i'm certain to become extremely unpopular around here----- even if enough info is out there to figure it out------ it's just three parts and quite easy to do--- it has nothing to do with the non-stock changes in my 25 watter or the 250kA Gain pot, although these changes do help in this particular amp----satisfying hard rock tone without mushiness (stays articulate even at extreme levels)---- and with the Lar/Mar PPIMV it delivers similar tone at greatly reduced vol levels, if wanted..................gldtp99
Les Paul Man
Post by Les Paul Man » Tue Oct 05, 2010 3:22 am
of course its on modding a JCM800 to #34 specs......because Frank did the #34 mod to Slash's jcm800
And Yes I do know the #34 mod, but out of respect for Frank, I cant give anyone the mod.....so dont ask.....sorry
'83 Marshall JCM800
'03 Gibson LP Classic
'86 Laney AOR "ProTube"
gldtp99
Post by gldtp99 » Wed Oct 06, 2010 8:40 am
Just returned from my shop where i finished up a restore job on a friend's '65 Fender Princeton Reverb----after testing the Fender out thoroughly i plugged into the 25 watt #34 head to see if i still felt the same way about the sound.
It kicks butt !!! i did more single note playing on the neck pickup than before and this amp delivers !!! Sometimes i get excited about a new build or mod and love it at first but feel differently after a few days and further testing----not in this case, it seems to be the real thing.
i still need to A/B it against my 50 watt #39-type head ----- it's hard to get free time to spend on amps lately---- my 'real' job is demanding almost all my time.
Plans to mod my Marshall 4010 50 watt JCM 800 1x12 combo to #34 specs are still in place......when i get time............gldtp99
gldtp99
Post by gldtp99 » Sat Oct 16, 2010 8:26 am
Got the #34 mod to my Marshall 4010 combo installed/tweaked------ most important part in this one was moving NFB supply to 16 ohm tap from 4 ohm tap (factory stock in a 4010)----amp is sounding very good now during bench testing thru a 4x12 cab. I'll test different brands of EL34's and preamp tubes as i go foreward with this one. Then comes selecting the speaker for the 1x12 cab.
I A/B/C'd this 4010 against the #34 25 watter and the 50 watt #39-type (four preamp tube) head i did earlier----all amps sounded very good---- hard to tell which is my favorite--- :what: Another player was over and witnessed all this and he liked the two 50 watters the best---- but he listened only because he didn't bring a righthanded guitar to play---- i'm a lefty and i offered him any of my guitars to play, but he declined.
I've contacted a very talented player to come and record demos of two of these Slash-type amps in the studio across the hall from my workshop (his two favorites out of these three amps)---we'll do this over Thanksgiving break and i'll post the clips then.....................gldtp99
uiovbged332
Post by uiovbged332 » Wed Jul 06, 2022 8:15 pm
Michael Jordan Shoes
Nike Running Shoes For Men
Louboutin Heels
New Nike 2019
Air Force Ones
Basketball Shoes
Christian Louboutin Outlet
Nike Air Max 95
Christian Louboutin Shoes Outlet
Pandora Outlet
Nike Shoes
Nike Outlet
Yeezy Sneakers
Golden Goose Sneakers
Nike Sneakers
Nike Cortez Men
Lebron Shoes
Nike React
Nike Basketball Shoes
Pandora Rings
Ferragamo
Nike Air Max 270 Men
Air Max 720
Louboutin shoes
Adidas NMD
Nike Shoes
Pandora Jewelry
Nike Running Shoes
Air Jordan Sneakers
Pandora Canada
Nike Air Force 1 Women
Nike Outlet
Nike Outlet
Yeezy
Yeezy
Nike Sneakers Outlet
Pandora Charms
Nike Outlet Store
Air Max 98
Lebron James Shoes
Nike Outlet Online
Kevin Durant Shoes
Nike Air Max 98
Pandora Jewelry
Jordan 11 Gamma Blue
Yeezy Boost 350 V2
Nike Shoes For Women
Cheap Nike
Pandora Jewelry Official Site USA
Adidas Ultra Boost
Kyrie Basketball Shoes
Air Jordan 13 Retro
Pandora Necklaces
Nike Factory
Stan Smith Adidas
Nike Shoes For Kids
Pandora Jewelry Rings
Nike Shoes
Jordan Retro 11
Red Bottom Shoes
Nike Air Force
Air Max 2019
Nike Store Online
Adidas Sneakers For Men
Nike Cyber Monday 2020
Red Bottom Shoes For Women
Nike Shoes
Nike
NMD R1
Red Bottoms
Air Jordan Sneakers
Nike Air Monarch
Nike Clearance Store
New Nike Shoes 2019
Lebron 16
Nike Outlet Store
Nike Free Run
Nike Cortez Men
Air Jordans
Pandora Bracelets And Charms
Nike Air Zoom Pegasus 36
Nike Outlet
Nike Shoes
Nike Air Presto
Yeezy Boost 350
Pandora Earrings
Valentino Shoes
Nike Air Max 720 Men
Pandora
Nike Air Max
Lebron 16
Salvatore Ferragamo Shoes
Nike Factory Store
Pandora Canada
Jordan Retro
Moncler UK
Huarache Shoes
Jordan Shoes
Nike Free Run
Adidas Yeezys
Nike Sneakers
Pandora Rings
Pandora Charms Sale Clearance
Nike Sneaker
Ultra Boost
Asics Outlet
Yeezys
Kanken Backpack
Pandora
Nike Clearance Outlet
Nike Air Max 95
Ferragamo
Vans
Nike Outlet Store
Fjallraven Backpack
Nike Clearance
Kyries Shoes
Yeezy Boost 350
Pandora Bracelet
Yeezy 500
Kids Jordan Shoes
Nike Zoom Pegasus
Nike Outlet
Nike Factory Outlet
Air Force 1 High
Nike Store
Mens Nike Shoes
Nike Lebron 17
Yeezy Shoes
Christian Louboutin Shoes UK
