Thanks for the heads up, Coffee!CoffeeTones wrote: ↑Sat May 06, 2023 12:04 pmRG58 - appears to be solid instead of stranded core conductor, 22 AWG. .195" diameter, about 31pF per foot, high working voltage rated, insulation is not great and will melt easily if heat applied too long. I'd try to seek out some coax with Tefzel or Teflon insulation, tinned and stranded copper core 22 - 20 AWG. You assume the risk. If you choose to do the mod, do it as best and safely as possible.
Here in Brazil there is no suitable cable for hot shield.
I'm thinking of asking a friend to bring this cable from Europe, it looks good!
https://www.tube-town.net/ttstore/coaxi ... g-187.html
What do you think of this one?
Thank you so much!
