Needs a bit of tweaking to get the bass under control.
Change the second stage to 10k .1u and the 220k on the gain pot to 150k or even 100k.
Will do! It will be more #34 like though?
Here you go. Mk7 with a 10k/.1 stage and .1 presence.CoffeeTones wrote: ↑Thu Jun 17, 2021 11:32 amIf you take that MK7 topology and plop another modest gain stage in somewhere, you might find the golden egg. Many times modders follow a trend like that and I'd bet that many 80's rock records have MK7 lineage amp tones on them. I might not put a snubber on stage 1 plate since that stage is not peaked much. I'd try snubbing one of the later stages unless the stage 1 snubber is made necessary by some behavior. I doubt .68uF presence will work with the MK7 since the first stage is passing most frequencies. I may do that mod myself in a few days. There is a JCM 800 circuit just sitting here![]()
Me likey! Good job!gluke wrote: ↑Sat Jun 26, 2021 6:01 am150k and 10k/.1 sounds like this:
WTTJ:
https://youtu.be/iWcioYVXeaM
10k // .1 placed where? NFB value?gluke wrote: ↑Sat Jun 26, 2021 6:04 amHere you go. Mk7 with a 10k/.1 stage and .1 presence.CoffeeTones wrote: ↑Thu Jun 17, 2021 11:32 amIf you take that MK7 topology and plop another modest gain stage in somewhere, you might find the golden egg. Many times modders follow a trend like that and I'd bet that many 80's rock records have MK7 lineage amp tones on them. I might not put a snubber on stage 1 plate since that stage is not peaked much. I'd try snubbing one of the later stages unless the stage 1 snubber is made necessary by some behavior. I doubt .68uF presence will work with the MK7 since the first stage is passing most frequencies. I may do that mod myself in a few days. There is a JCM 800 circuit just sitting here![]()
WTTJ:
https://youtu.be/UvRL0YDmH8M
Nightrain:
https://youtu.be/Xj8FQe791k4
10k // .1 between which two stages? NFB value?gluke wrote: ↑Sat Jun 26, 2021 6:06 amMk7 with the 10k/.1 stage between the two stages.
WTTJ:
https://youtu.be/U5vx22X_5q4
Nightrain:
https://youtu.be/3OUCdE-oajo
First one is first two stages if mk7 then 10k/.1 stage
That one is 10k/.1 on the second stage.
Thanx! I think I need to get a LP of some sort. SCOM just doesn’t work on a P90....
This sounds pretty darn good!gluke wrote: ↑Sat Jun 26, 2021 6:01 am150k and 10k/.1 sounds like this:
WTTJ:
I’ll do some more clips. We are back at the office now so I don’t have the whole house to myself all day long anymore....... coffee breaks at the home office was brilliant for small tweaks and recording clips.
