Calling Rockstah - 1959 HW to 12xxx series spec
MP3's of MAR 100-C:
Baretta Darkburst PU C414mic No GE10 No Verb
http://www.soundclick.com/player/single ... 98438&q=hi
Baretta Darkburst PU SM57mic No GE10 No Verb
http://www.soundclick.com/player/single ... 98449&q=hi
Baretta Darkburst PU C414mic GE10 No Verb
http://www.soundclick.com/player/single ... 98454&q=hi
Baretta Darkburst PU SM57mic GE10 No Verb
http://www.soundclick.com/player/single ... 98460&q=hi
Baretta Darkburst PU C414mic GE10 Reverb
coming soon.....was messed up will have to redo and re-edit this post....
Man the GE10 definelty adds Gain. I can see how this may have been all Ed used in front of his plexi for VH1.
Baretta Darkburst PU SM57mic GE10 Reverb
http://www.soundclick.com/player/single ... 98474&q=hi
Main Soundclick page if above links do not work:
http://www.soundclick.com/bands/default ... dID=717849
My first project: 1959HW to 12xxx Courtesy of the Late Great Rockstah a.k.a. Edward Van Abrahamian
I don't like it with the dry recordings....too much fuzzy noisy stuff.rockstah wrote:yes it does add gain slammin the front end.
so before i say anything what do u think of the new choke?
However, with the verb especially playing RWTD it kinda sounds like the fuzzy sound you hear on VH1, at least to me.
So at this point not sure if I like it or not?
Put NOS Mustards back and removed SOZO Premium Mustards
MP3's of NOS Mustards: (Had to play/record these fast, late and don't want to make the ol' Lady Mad with the Dimed Plexi.)
http://www.soundclick.com/player/single ... 99364&q=hi
http://www.soundclick.com/player/single ... 99372&q=hi
Baretta Darkburst PU C414mic and GE10
http://www.soundclick.com/player/single ... 99375&q=hi
Baretta Darkburst PU SM57mic and GE10
http://www.soundclick.com/player/single ... 99382&q=hi
Baretta Darkburst PU C414mic and GE10 with Reverb
http://www.soundclick.com/player/single ... 99394&q=hi
Baretta Darkburst PU SM57mic and GE10 with Reverb
http://www.soundclick.com/player/single ... 99401&q=hi
If above links do not work click here for main page:
- rockstah
Yea I'm not liking the new choke either.rockstah wrote:i don't think i like the new choke.
sounds more like the top of the snare drum but i cant hear the drum itself. if that makes sense.
try the 7h in the store.
refresh my memory here - which OT and PT are we hearing?
OT = George's Dagnall Clone
PT = George's Dual Tap using Low Volt Taps
This be the choke your recommending?
http://store.metroamp.com/product_info. ... cts_id=346
And what about the Allen Bradley NOS resistors? Changing resistors carbon film to carbon comp even though same value affect the tone much?
http://store.metroamp.com/product_info. ... cts_id=486
- rockstah
[quote="rockstah"]
quote]
You mean snare rattle dude, from the bottom of the snare. Yes it's very pronounced since the new choke.
VH, try pulling some of those ickies out of the GE10, try setting it flat n just use it to push the front a bit, and that reverb man, either take a LOT out or don't use it at all. If I may.
quote]
- rockstah
no. i meant what i wrote. it was to imply that there is not as much of a complex depthness going on now. i only hear the head and not the drum. i do see what u are saying as well. there is alot of junk around the notes now with the new choke.
You mentioned earlier about trying the Superbass tone stack. This what I need?:rockstah wrote:you can if you want to experiment. i never found them of any value for my likes - i don't use any carbon comps and they weren't in a 67-68 plexi either.
that choke is the one.
http://store.metroamp.com/product_info. ... cts_id=104
http://store.metroamp.com/product_info. ... cts_id=138
And cootboy mentioned changing the reverb...take alot out....I am using PTLE7 and The Dverb plug in. Is this the plug in you use? If yes, what settings would you recommend?
