transformers between 68 and 78
- rockstah
what changes if any took place between 68 and 78 to the transformers?
Rockstah, my understanding is that the EPA (Environmental protection agency) outlawed certain elements in '75, mercury and lead, which was probably loaded in the iron in the early trannies. Ever notice that heavy "knock" in the old marshalls, that certain frequency that jumps out at ya, I bet that's the reactive mercury and lead (hint mercury magnets was around since like the 50s, hence the mercury name??); Also, ever notice that fire resistant material in the early boards, I think they call it asbestos, that was outlawed also. Too bad, it made the best anti-heat material in the amps...
68 Marshall JMP 100 Plexi
69 Marshall JMP 100 Plexi
71 Marshall JMP 100 Metalface
66 BF Fender Pro Reverb
67 BF Fender Super Reverb
- Brian Wallace
- Supporting Advertiser
- novosibir
Are you absolutely shure about this?Brian Wallace wrote:As for lead, the 60/40 solder you buy right now is currently RoHS approved.
Larry
- Brian Wallace
Re:
Sorry I don't understand which are the asbestos boards in marshall amps. Are you referring to circuit board or to transformer cardboard/paper? Thank you very much!Bunnest wrote: ↑Mon Aug 13, 2007 12:19 pmRockstah, my understanding is that the EPA (Environmental protection agency) outlawed certain elements in '75, mercury and lead, which was probably loaded in the iron in the early trannies. Ever notice that heavy "knock" in the old marshalls, that certain frequency that jumps out at ya, I bet that's the reactive mercury and lead (hint mercury magnets was around since like the 50s, hence the mercury name??); Also, ever notice that fire resistant material in the early boards, I think they call it asbestos, that was outlawed also. Too bad, it made the best anti-heat material in the amps...
