Hey Jon, no that is not correct. You're taking 70% of the plate dissipation divided by the plate voltage. However, the max bias is 70% of plate dissipation only. On top of which, 30 watts is max plate dissipation for a 6L6, not an EL34. 25 Watts is max dissipation for EL34s.gtrbarbarian. wrote:EH,
The formula I am using to get the bias is this
(30w/470v) * .7 = .0446
Is this not correct?
With your equation using the values shown above, you would actually be biasing at 20 watts, well above 70% max plate dissipation for EL34s, which is 17.5 watts.
So you'd actually want this equation:
(25*0.7)/Plate Voltage=Max Bias Current
To simplify it, 70% of 25 is 17.5. So here is the simplified equation:
17.5/Plate Voltage=Max Bias Current
I know that Groove Tubes claims that their EL34s can dissipate 30 watts, but judging from the fact that this is coming from Aspen Pittman, I wouldn't even try it. Aspen is #1 of people on my shit list since his power tubes don't last for shit and half of what he says is bullshit. Stay with 25W max plate dissipation and ALWAYS use the above equation to figure out max bias current.
Now remember, the above equation just gives you the MAX bias current value. You can bias anywhere below that, depending how the amp sounds to your ears at different bias settings. Mess with the bias until the amp sounds right to your ears. However, DO NOT GO ABOVE THE AMOUNT YOU GET IN THE EQUATION!!! I cannot stress that enough.
I know you're a beginner in all of this so anytime you need to know something just let me know. You can even email me personally as well.
BTW my real name is Jon also.
Jon
