Thanks for your feedback bulldozer1984, that blending option you mention it is the way that I have been using it.bulldozer1984 wrote: ↑Tue Feb 02, 2021 2:58 amIf your reverb plugin has a mix or blend knob, you ...........
Julio
I agree, and I always use an aux. But, there are no rules, and if the mix control gets the desired result, then all good. If you want to eq the reverb, or share the reverb, or automate the reverb, or compress the reverb, or gate the reverb, etc, then yes an aux makes more sense.Unique wrote: ↑Tue Feb 02, 2021 3:27 pmYou can, but you lose some control. You want to put it on an Aux track, even if your plugin has a mix slider. There's so much more you can do with it when it's on an Aux track. Also, when you put a plugin on the insert you have to be aware of the order, and with what other plugins your using it with. Some don't play nice with others, and can affect the sound of other plugins before them. Plugins are finicky with their order on the inserts.bulldozer1984 wrote: ↑Tue Feb 02, 2021 2:58 amIf your reverb plugin has a mix or blend knob, you can put that straight on the track. If not, then you should use an aux track as Unique suggested.sonoman1979 wrote: ↑Mon Feb 01, 2021 5:30 pm
This information is very useful, thank you very much! I will keep experimenting
It was. I found the power amp had been modded to plexi feedback. Changed that and added shield trick on the first stage and it's already alot bighter.CoffeeTones wrote: ↑Sat Apr 17, 2021 8:15 amYes, The sound is headed in the right direction so far. The clip sounds a little dark.
I mostly used the #34 schematic and info in this tread. I'v been following this tread since the beginning waiting to get my hands on an amp with an extra tube so I can try this stuff. So big thank you to all you guys who kept this going. When this one came for sale last year so I had to get that and installed the tube myself. Greatly inspired by Larry's beautiful mod pics, but I'm not that patient and I don't think guys in the 80s were that tidy so I just threw everything in there around the added tube socket. But it works and doesn't squil so I'm happy.CoffeeTones wrote: ↑Wed Apr 21, 2021 8:21 amSounds pretty good. Which schematic and speakers are you using?
Yeah for those of us who are 5 years late to the party, ha ha ha.CoffeeTones wrote: ↑Wed Apr 21, 2021 2:29 pmSo you have a #34 with extra tube with 10k cathode? Can you give more details or pics? Let's give the thread another boost
Cool. 10k input grid on that stage? Can't see all the color bands. 1n bright cap? Post more clips when you get the chance. The amp sounds pretty meaty. I like it.gluke wrote: ↑Thu Apr 22, 2021 2:17 amLet's see if this works. The anit-Larry way of installing the #36 mod.....
https://imgur.com/a/PdCFYl8
