dukeamps
Post by dukeamps » Wed Nov 30, 2022 10:52 am
CoffeeTones wrote:
Wed Nov 30, 2022 9:25 am
dukeamps wrote:
Tue Nov 29, 2022 10:46 am
CoffeeTones wrote:
Tue Nov 29, 2022 8:49 am
Nice sounding TeleGib. How ya been?
Keeping ok, and you ?
I build this Tele with the same wood you would use for a LP, HB are A5, the amp spec is a tweaked Levi 36 mod, speakers G12m25w BB
:toast:
Which exact bridge plate did you use?
I need to get some pics of my Tele. It has a Warmoth ash body, translucent butterscotch, forearm drop upper bout, Duncan pearly gates Tele size bridge, SM1 mini humbucker neck pickup set. Fender deluxe neck 9.5 radius IIRC. I built it several years ago.
My guitar started out like this:
https://shop.espen.de/en/Tonewood-E-Gui ... aster.html
Here is the plate I used:
https://www.rockinger.com/en/parts/hard ... e-for-tele
:toast:
dukeamps
Post by dukeamps » Wed Nov 30, 2022 11:14 am
CoffeeTones wrote:
Wed Nov 30, 2022 9:43 am
No hot shield yet. A tweak or two to come.
https://drive.google.com/file/d/1kaSz-T ... share_link
Nice.
:toast:
CoffeeTones
Post by CoffeeTones » Wed Nov 30, 2022 11:16 am
Cool, I don't have wood working tools. Kudos to you! Is that bridge made of steel or some other alloy?
dukeamps
Post by dukeamps » Wed Nov 30, 2022 11:19 am
I just tested it there with a magnet and it sticks lol, so it must be steel.
CoffeeTones
Post by CoffeeTones » Wed Nov 30, 2022 11:47 am
Cool, do you think brass or stainless steel would tweak the bride tone? Probably not as much as on a standard Tele bridge but if you get a lot of feedback / brightness, it might be worth a shot. Suppose to be an eddy current thing from what I've read. Some of the stock Teles came with brass bridges. I believe the American and Custom Shop versions. I'd have to check them again them to be sure. It's been a while. Some lower grades of stainless will attract a magnet, but a lot less than plain steel.
dukeamps
Post by dukeamps » Wed Nov 30, 2022 11:59 am
I haven't thought much about that sort of thing, I'm just glad that it sounds good.
Unique
Post by Unique » Wed Nov 30, 2022 1:07 pm
That is sounding good and definitely on track. I'll be anxious to hear the final results! That was also some pretty good playing, I might add. What pickups were you using? I love the way your power chords were sounding, aggressive, balanced, and in tune. Nice job!
CoffeeTones
Post by CoffeeTones » Wed Nov 30, 2022 1:18 pm
You'll have to ask Sonoman. My #36 spec, his playing.
Unique
Post by Unique » Wed Nov 30, 2022 1:19 pm
I can't say much about using a steel bridge on a Tele, but I tried one on my LP once and did not like it. I know, a different animal, but maybe not so much with the same woods? The highs were brighter, but there were less mids, and the bass got a tad bit too boomy. It also seemed to focus more on the fundamental note, and less with the harmonics. Which is possibly what made the bass a more boomy. With this steel bridge, I was also using steel bridge post, steel thumbwheels, and steel TP studs, so maybe just too much steel altogether. I still use the steel TP studs, wouldn't have it any other way, but the rest got swapped out as fast as I could do it.
dukeamps
Post by dukeamps » Sun Dec 04, 2022 12:29 pm
CoffeeTones
Post by CoffeeTones » Sun Dec 04, 2022 12:36 pm
That Tele is getting it done!
dukeamps
Post by dukeamps » Sun Dec 04, 2022 12:38 pm
:toast: A5
dukeamps
Post by dukeamps » Sun Dec 04, 2022 1:26 pm
dukeamps
Post by dukeamps » Sun Dec 04, 2022 2:02 pm
Unique
Post by Unique » Sun Dec 04, 2022 3:18 pm
That sounds so good, and close to the original, that when SCOM started playing it sounded like you were doing the 'Haas' effect with your recording. Great job!
