Superlead blowing mains fuse
- lp1987x
I have a '74 Superlead that keeps blowing the 4 amp mains fuse. With no power tubes installed, the fuse does not blow. In checking voltages, I'm seeing 2.8 volts ac at the heaters. However, I'm only seeing -5.8 volts dc on pins 5. Does anyone have any idea what might be causing this odd reading and if this could be the issue?
Craig
Re: Superlead blowing mains fuse
measure AC and DC voltage in the bias circuit
Already have a thread on this working through the problem in the logical way on plexi palace Marshall section
