Master Volume installed - pre-phase inverter at the effects loop (before or after?). Green lead connects to board at BN4 and the blue lead goes back to the effects loop card ;
Cap installed on across R11, 330uf if I'm not mistaken;
Hum balance VR removed and replaced with 2 resistors and what looks like 2 caps beneath (at R31, R32 and VR2)? Would love more information on this one. Why the caps under the resistors and what benefit does this mod bring?
I'm considering having the master volume re-done to a post-phase inverter Trainwreck style (professionally). What are your thoughts on the pros/cons of making that change from what is currently installed here? Any comments on the proximity of the master volume control to the power and standby switches? Am I asking for trouble leaving it there, introducting AC noise into the signal path?
