Marshall Factory Biasing
Posted: Mon Mar 01, 2004 6:30 pm
Hey guys, I found me a sweet JCM 800 2204 made 6/29/83 Vertical inputs and it rocks! It has been converted over to EL34's too
But here is the question, in my research for building one of these bad boys I came up with some info from Marshall on voltages. It has a comment about bias approx -44v on pin 5 (6550 and -33v on EL34's)
So do they bias them from the factory at a set voltage based on tube type at pin 5? I am curious how the factory does it.
I did the Shunt method and the Resistor method. Depending on which site your on determines what is the BEST way. But with everyone recomends playing it and adjusting by ear and use the bias as a guideline to not get them TOO hot. What difference does it make as what method you use long as long as the plates dont glow OR burn out every few months?
Also they claim that unless you have a Fluke you cant do the shunt method as it will be off. But there again, if you are adjusting it by hear what the hell does it matter if they arent glowing or dieing? Enquiring minds wanna know! lol
[/list]
[/list]
