JTM45/100 complete !! Pics.
Wayne
Re: JTM45/100 complete !! Pics.
Post by Wayne » Tue Jul 21, 2009 4:13 am
Roe wrote:I guess its hard to find decent new preamp tubes that can stand the HIGH preamp voltages in this amp. for instance, v2 in mine has a voltage of 360v - something which will easily kill the tung sol and many sovteks. Also, I must admit that I cannot stand the jj 83s
Are you using the HV taps on the 43 transformer ?
Are you saying that pin 6 (and 1) of modern ec83's may not be able to take over 300v ??
I wrote my values down somewhere.
Might have to re - check.
I used the 490 B + tap instead of the 560 and i KNOW it was exactly that.
You've got me worried now.
I'd better go check.
I think the JJ's sound fine - guess it's a matter of taste.
Wayne
:D
Wayne
Post by Wayne » Tue Jul 21, 2009 5:07 am
Hi all.
The data sheets for all 12AX7's i could find put max plate voltage at 300v.
Georges own 43 PT voltage chart shows pin 6 on V2 at 360 volts which is exceeding the max plate voltage - right ??
How can this be right ?
There's nothing like checking for real with a meter though !
I can't find my notes so i will have another look but i'm pretty certain that my plate volts on V2 were well under 360v.
Nothing seemed out of the ordinary - BUT - i did not compare them to any chart.
I just had a quick check.
Mines the "Dickinson" version so I'll do a complete test and post all my readings for the "Dickinson" version in a layout similar to Georges standard JTM45/100 voltage chart in the next few days.
I used the Marstran 43 PT version - which had slightly lower (not by much) B + than the 500v recorded on Georges Voltage Chart.
Any thoughts ?
Wayne
:D
Post by Roe » Tue Jul 21, 2009 9:23 am
Wayne wrote:Hi all.
Any thoughts ?
Wayne
:D
the old tubes would stand very high voltages. the new ones dont - the cathode follower (v2) is the main problem. JJs seems to handle much higher voltages than the tung sol "RI"s.
I use the 230v primary and the 490v secondary on brians 1202-43. biased at 65% diss that gives me a 505v b+
Big Mike
Post by Big Mike » Tue Jul 21, 2009 11:29 am
Yup. I dislike the sound of JJ's so I generally use a Nos GE12AX7 in my CF stages, or better if I can find it. My 50 has a telefunken there.
My main gig amp is a cathode bias design with only 2 preamp tubes (No CF) so I generally use TungSol or Tungsol/EH or sovtek mix.
They do sound good with NOS stuff too though.
Metroamp kit JMP50 - CM OT
Marshall 2550 Jubilee
Scumback Speakers
