Will a combo 45/100 work?
timsmcm
Post by timsmcm » Tue Apr 21, 2009 12:55 am
I am in the process of building a 45/100 and I am seriously thinking about putting this chassis in a combo type cabinet with two Celestion golds. My question is will the 2/ 12 combo in a cabinet that is a little bigger than the average cabinet, sound big enough to bring the goods out of the mighty 45/100? On paper it might not seem that good but my intuition tells me that this could be my tone quest in a box. I love the sound of the golds and to be pushed to the brink by the 45/100 will have those golds close to cookin to the brink. And I also thought it would tighten it up a little if it was a semi closed back cab in a little bigger size. Please let me know your feelings, criticisms. Give me both barrels.
Re: Will a combo 45/100 work?
Post by Roe » Tue Apr 21, 2009 4:14 am
may work well.
gutpile
Post by gutpile » Wed Apr 22, 2009 9:41 pm
Consider your back as well!!! This would top out easily over 100 pounds!!!
Metro Clips
MacGaden
Post by MacGaden » Thu Apr 23, 2009 12:53 am
gutpile wrote:Consider your back as well!!! This would top out easily over 100 pounds!!!
+1.. That was my first thought. And: Can an Alu chassis support those transformers in that position ?
This would be a very impractical beast.
MacG.
shakti
Post by shakti » Thu Apr 23, 2009 5:55 am
+1.
Why not try a JTM45 with a solid state rectifier? It should make for a more manageable package, while still having much of the same character.
thousandshirts
Post by thousandshirts » Sat Apr 25, 2009 7:19 pm
timsmcm wrote:I am in the process of building a 45/100 and I am seriously thinking about putting this chassis in a combo type cabinet with two Celestion golds. My question is will the 2/ 12 combo in a cabinet that is a little bigger than the average cabinet, sound big enough to bring the goods out of the mighty 45/100? On paper it might not seem that good but my intuition tells me that this could be my tone quest in a box. I love the sound of the golds and to be pushed to the brink by the 45/100 will have those golds close to cookin to the brink. And I also thought it would tighten it up a little if it was a semi closed back cab in a little bigger size. Please let me know your feelings, criticisms. Give me both barrels.
Do whatever you want. But I'd avoid such a project myself for a few reasons
1.) I don't believe in combos - speakers are in too close a proximity to tubes, causing rattle, noise, etc.
2.) Moving around a heavy combo is a bigger pain than moving two lighter boxes IMO. One box is a non-plus.
3.) I firmly believe that my 45/100 circuit deserves nothing less than a 4x12. Preferably two.
4.) Celestion Golds @ 50w x 2 + 45/100 peaking over 100W = a chance of dead speakers
Post by Roe » Mon Apr 27, 2009 3:33 am
I believe the golds will handle it for a while. could last months or years. depends on a lot of factors
timsmcm
Post by timsmcm » Mon Apr 27, 2009 1:35 pm
It seems to me the golds in that application would be a lot like the blues in a vox ac30. The vox puts out a little more than 30 watts and the vox blues were 15 watters and They were a fantastic combination when cranked.
amp boy
Post by amp boy » Mon May 04, 2009 6:14 pm
heads are versatile.
play through different cabs etc.
tubes enveloped in all that sound pressure within a 100watt combo............... :cry:
2x65watt Scumnicos.
their silver.
therefore........
http://www.youtube.com/watch?v=vQqrt0nM_vw" onclick="window.open(this.href);return false;
:D
......saving for my 1st build, may save me.
Go and have a bite........
http://www.youtube.com/watch?v=ll7rWiY5obI" onclick="window.open(this.href);return false;
