The 8.2K resistor drifts too much
BoogieEngineer
Post by BoogieEngineer » Mon Jul 16, 2012 3:42 pm
I got a 8.2K dropper that reads 9.37K, so I had to get another one, planning on using the old on in place of the 10K. But this new one reads 9.41K :( Thoughts?
toner
Re: The 8.2K resistor drifts too much
Post by toner » Mon Jul 16, 2012 4:51 pm
I'm not sure why you posted this but... :what:
Maybe your meter isn't very accurate? The slight variation in resistance there will have very little effect on voltages, etc. so I wouldn't worry about it. In case you're talking about CC resistors, it's quite common for those to read higher than marked but I wouldn't use CC's there anyway.
Post by Roe » Mon Jul 16, 2012 5:14 pm
9k4 is fine. try testing the one in old marshalls instead of only following the schematics
BoogieEngineer
Post by BoogieEngineer » Mon Jul 16, 2012 9:43 pm
toner wrote:I'm not sure why you posted this but... :what:
Yeah they are both CC's. Why wouldn't you use CC's there? Almost every JTM45/100 build I've seen has got a CC in there. The ones I've got are both 2W if that makes a difference.
BoogieEngineer
Post by BoogieEngineer » Mon Jul 16, 2012 9:45 pm
Roe wrote:9k4 is fine. try testing the one in old marshalls instead of only following the schematics
Thanks, good to know. What about the 10K near the preamp cap? I guess I could use the 9.3K in place of the 8.2K and the 9.4K in place of the 10K? :)
toner
Post by toner » Tue Jul 17, 2012 10:43 am
BoogieEngineer wrote:Yeah they are both CC's. Why wouldn't you use CC's there? Almost every JTM45/100 build I've seen has got a CC in there. The ones I've got are both 2W if that makes a difference.
They can add noise and drift in resistance. They are historically correct though. (I was just making a general comment about CC's.)
BoogieEngineer
Post by BoogieEngineer » Tue Jul 17, 2012 12:48 pm
I'm using CC's just for several spots. As for tone, general consensus is that there is no noticeable difference from what I've heard. I find them look cool though
Post by Roe » Fri Jul 20, 2012 12:23 pm
yes, it doesn't matter much though. different tubes will draw different amounts of current, affecting voltages and tone
BoogieEngineer
Post by BoogieEngineer » Fri Jul 20, 2012 2:44 pm
Thanks Roe. I actually got another 8.2K from Valvestorm which reads 8.4K on my meter, so it goes to the 8.2K position. The 9.4K goes to the 10K place, so I'm all good now :)
