http://s64.photobucket.com/albums/h174/ ... 0%20Build/" onclick="window.open(this.href);return false;
I populated the boards while waiting for the other shipments. The chassis got here on Friday and I spend the whole weekend to finish the build. I tried to slow down but I can't even sleep well knowing it's there waiting to be built. I don't have a wire stripper and that slowed me down quite a bit though.
Rushing the work has taken its toll however. I made 2 mistakes that I know of. The first was that I cut one leg of the 0.1uF on Presence pot too short. I fixed that by soldering a short buss wire to the leg and then to the pot. The 2nd mistake was that I soldered the purple wire from the 27K resistor to the Bass pot. The wire was cut too short to reroute to the Presence pot. So I added a buss wire there, tubed it and heat shrinked the joint. My question is is there any harm in fixing those errors that way? Could add a little noise at least I guess?
Btw I fired the amp up for the first time at midnight. Thanks to the PPIMV I was still be able to play for a good hour. Can't wait till tomorrow to play it more
