Simple set up.
Posted: Mon May 04, 2015 2:21 am
by stalkertwo
Hello. I´ve got super champ x2. And i using voice 9. And question, what Hendrix used settings? if more treble or bass you now. I like sound from Woodstock and Isle of wight. I have fuzz on almost max really almot, volume on half. And basic settings amp? Currently I use gain 7, treble 5-6 and bass 4-5. What is the best? Thank you for answers.
Re: Simple set up.
Posted: Thu May 14, 2015 5:14 pm
by theactor19
Its going to be hard to get his tone with your setup, however there is a guy on youtube with a vibrochamp that makes his own hendrix-style pedals that got a really good hendrixy tone. I would say for your amp, use your ears and eq til you get close. One trick, and this may be more for vintage amps but it could help, is to crank the treble on your amp all the way up and use your guitar tone knob to tame it a bit. It'll get rid of a lot of the mud from the fuzz.
Re: Simple set up.
Posted: Thu May 21, 2015 2:32 am
by stalkertwo
So i set treble high, about 7? Thank you.
Re: Simple set up.
Posted: Thu May 21, 2015 4:51 pm
by Xplorer
follow your ears while trying various settings. telling you : 7 , 4 , 10 .... it won't mean much.
Re: Simple set up.
Posted: Fri May 22, 2015 5:32 am
by stalkertwo
Ok and bass?
Re: Simple set up.
Posted: Sat May 23, 2015 7:16 am
by Xplorer
.... your ears !
Re: Simple set up.
Posted: Sat May 23, 2015 11:43 am
by peter25
Yeah there isn't a golden setup or something. I've seen marshalls with the mids scooped getting a Hendrix sound.... no rules. Just listen to what seems right to you. Only advise I can give you is set the amp so that you have clean sounds whith you guitar volume turned down to around 6 and overdriven sounds with volume at 10. Start from there. After gain I set mid, treble and end with bass to thicken things up. Most important in getting the sound right is in how you play and how hard your attack is.
Re: Simple set up.
Posted: Sat May 23, 2015 12:51 pm
by JimiJames
stalkertwo wrote:Hello. I´ve got super champ x2. And i using voice 9. And question, what Hendrix used settings? if more treble or bass you now. I like sound from Woodstock and Isle of wight. I have fuzz on almost max really almot, volume on half. And basic settings amp? Currently I use gain 7, treble 5-6 and bass 4-5. What is the best? Thank you for answers.
Do this:
Amp on 10 - EVERYTHING.
Fuzz 10 - Gain as volume level control. (0-6 max)
This will define the "max" Tone of the your gear combined for that particular low watt amp.
Guitar volume control & rolling off the desired EQ..... a Slight Return
You cannot "loose" the noise like this, but you will gain max desirable tones.
Players have dimed a Fender Champ placed in an isolation booth of some type or another. IIRC one of Buddy Guy's albums is recorded in this manner. Shoulda' been Marshall's
Re: Simple set up.
Posted: Sat May 23, 2015 4:42 pm
by Tek465b
I think the volume settings affect the tonal charistic ALOT more that the bass/mid/treble EQ.
"The sweet spot" is in the various volume(amp volume, fuzz volume, guitar volume...) settings.
0.1uf on cathode of preamp are a bad thing(v1 and v2). i get the same effect if i eq down about -2 to -4 db at 250hz to 2khz while playing woodstock dvd. and it sound BAD..
To me bass/mid/treble do just that.. change the bass middle and treble they are pretty transparent to me(tonewise).
Volume setting and your attack is really what make the difference.
I don't like a marshall cranked to 10. make it sound nasal or something like that to me.
I just crank the fuzz volume until it do very well with the vibe then i know am set
Q1 transistor in a fuzzface make all the difference with a strat too..
To me these are the only things that really do make a huge difference(in a positive way).
Re: Simple set up.
Posted: Sat May 23, 2015 8:04 pm
by Xplorer
yeah, i'm more like tek , i set my marshall to about 7 - 8 maximum volume. a lot of presence.
and before that, the fuzz volume often at maximum, and maybe just a bit of fuzz , from zero to 2.
i like it that way , with the univibe preamp at max between the fuzz and amp.
then playing a bit with the strat volume from about 8 to 10.
Dave weyer described jimi's settings like this, and this is what makes the most sense to me when playing it.
you can go from some clean tones to some very nice Crunch just how you play the strings. very expressive.
this is a simple setup that peoples rarely do i think, just diming their amps, most of the time and they don't get the Hendrix sound this way imo.
Re: Simple set up.
Posted: Sun May 24, 2015 4:03 am
by JimiJames
I didn't see Marshall anything (or guitar). This thread is about a simple Fender Champ and a fuzz...
Check with Jimi's guy... Buddy Guy... He's still alive and well in Chicago...
Re: Simple set up.
Posted: Sun May 24, 2015 4:04 am
by stalkertwo
I set up, treble 8, bass 6, gain 8. Fuzz almost max. Volume half maybe almost half. I used on champ 4. Thank you.
Re: Simple set up.
Posted: Sun May 24, 2015 4:11 am
by JimiJames
stalkertwo wrote:I set up, treble 8, bass 6, gain 8. Fuzz almost max. Volume half maybe almost half. I used on champ 4. Thank you.
You're using the other channel? I don't think the Fuzz will be as effective compressed through that channel...
Re: Simple set up.
Posted: Sun May 24, 2015 4:21 am
by stalkertwo
I something record and post you ok. I using voice 4. But when i give gain on 6 or 5, it is clean but i want few crank sound. I mean without fuzz.
Re: Simple set up.
Posted: Wed Jun 03, 2015 2:52 pm
by theactor19
Here's the guy that gets a pretty good hendrix tone out of a vibro champ:
https://www.youtube.com/watch?v=QdL3PvRypyo
