Cliff speaker jack problem
sonofmickel
Post by sonofmickel » Mon Oct 19, 2015 1:46 pm
(120.18 KiB) Not downloaded yet
JCM800 build, sounds great.
Both cliff mono-speaker jacks work by themselves. I can plug into jack 1 or 2 and they each work by themselves.
If both are used, the second jack does not work, only the first one passes signal.
They both appear to be wired correctly.
Probably something simple.
Added pic. Ground is behind orange wire.
Doug H
Re: Cliff speaker jack problem
Post by Doug H » Mon Oct 19, 2015 2:39 pm
sounds like you daisy chained the ground wire.
sonofmickel
Post by sonofmickel » Mon Oct 19, 2015 4:16 pm
Fixed!
Loose connection using the "straight through" wiring technique.
I re-wired the output jacks "wrapping" the posts.
All good now.
Tip about wrapping the posts from Nik @ Ceriatone, I think he is just plain helpful.
