A friend of mine sent me a '69 Marshall Super Lead he bought in eBay to service.
The amp board is pretty pristine and untouched (have the red paint in all solder joints) but sounds terrible
First thing I did was forming the filter caps using Larry's method and it has great leaks (I don't go under 20v after 24h).
After that I tried the amp anyway and when you go above 3 on the volume, the amp has an horrible compression. Sounds small and ungly, so fisrt step will be changing the filter caps.
The power tubes needs to be changed too. It's a shame because is a quad of XF2's... but they measure very poor on my tube tester.
But the thing that really annoys me is the power cord socket.
The original bulgin plug is lost, I have a cable soldered straight into the amp, but I need something to put on the bulgin hole.
I tried before the drop-in replacements for bulgins that TAD sells but they don't fit on the hole, it needs to be enlarged anyway.
Do you know some alternative?
A pic:
thank you in advance guys
