Negative Feedback Wire
Dax
Post by Dax » Sat Nov 13, 2004 3:56 pm
Can someone refresh my memory about the differences hooking the negative feedback wire to the 4, 8 or 16 Ohm Tap. I cannot remember. Which one gives the most gain?
flemingmras
Post by flemingmras » Sat Nov 13, 2004 5:25 pm
That I'm not sure of. Try it and see. Matter of fact, you could just connect it to the speaker jack, then your amp's damping factor/gain will be the same no matter which impedance you're running.
Jon
Post by Flames1950 » Sat Nov 13, 2004 6:57 pm
The tap that provides the least negative feedback (i.e. the least voltage returned into the power amp) gives the most gain. The four ohm tap is the most gain, and it goes down sequentially as the amount of tranny winding you're using for feedback decreases.
Rickfox
Negative feedback wire
Post by Rickfox » Sun Nov 14, 2004 11:33 pm
Hey Guys!! I'm still loving my Metro 50, and I'm still up for tweaking and what will get me more overdrive. Will the negative feedback from 8 to 4 ohms get me more of what I want? What I mean is, when you are talking GAIN you mean distortion and not volume. ANY other info would be appreciated!
Already have a PPIMV, not much difference overall.
Thanks again!!
Rick
Post by Flames1950 » Mon Nov 15, 2004 8:06 am
If you're currently on the eight ohm tap moving the feedback wire to the four ohm tap will give you slightly more volume and distortion, at the expense of some tightness in your low end. It's a balancing act as to what you like better vs. how tight a sound you need.
