BIas Formula for Amp
Lou
Post by Lou » Sun Feb 06, 2005 1:11 pm
I remember reading a Bias Formula depending on the plate voltages.
Can anyone help me with this?
Lou
Lou
Toronto Canada
Metro 1959 X 2; Metro 1987 x 2 ; Metro JTM45; Metro '68 12xxx x 2;Metro 412 Slant 12M Heritage
1980 Gibson Heritage Elite WCR Pickups; 1980 JVSquire Strat; G&L Legacy ; Metro 412 Slant G12M Heritage
www.houseofnot.com
Post by Flames1950 » Sun Feb 06, 2005 1:31 pm
The formula for your target bias current is based on idling the amp at 70% of the maiximum heat that the tube plates can dissipate. Most EL34's, 6L6/5881's are rated for 25 watts of heat dissipation (nothing to do with the amount of power the tube can put out.)
70%(25watts)=E*I where E is your plate voltage, I will be the target maximum bias.
In the case of the 380-390 plate volts you (I think it was you?) posted in the Marshall forum,
70%(25watts)=380*I
17.5=380*I
17.5/380=I so your max bias current would be .046 amps, or 46mA.
Lou
Post by Lou » Sun Feb 06, 2005 1:56 pm
Dude Thank you soo much. That makes total sense...I will make adjustments to the amp as it is set at 35...
The fact that it is running lower , does that mean cleaner or diry tone out of output tubes...
Thanks again
Lou
Toronto Canada
www.houseofnot.com
