I'm shure, that no brand of output tubes that huge difference ever will noticerockstah wrote:yes 20k?
Larry
Yes I did hear the clip.rockstah wrote:did u hear the clip? this one blows away the other one tried. hands down. end of story.pongo316 wrote:Mark Whats your thoughts on this vesion compared to the previous ones used ???
this master sounds way better - WAY BETTERpongo316 wrote:Yes I did hear the clip.rockstah wrote:did u hear the clip? this one blows away the other one tried. hands down. end of story.pongo316 wrote:Mark Whats your thoughts on this vesion compared to the previous ones used ???
It sounded awsome as usual (no suppises there)
What's it sound like when you open her up a bit more (have you had the chance to do that yet)
As I have tried the other version but not that impressed ( but your clips with the eralier version sounded great too)
Whats that (orange)cap sitting on top of the .68 mustard ?
Did I miss some thing ?
i believe larry said u could use even 1/4 cabon film. (u can find thosee at radio shack).for this position - perhaps read previous pages. but im pretty sure.rtcook wrote:Mark/Larry,
Just to clarify, what is the minimun acceptable wattage for the 2.2M resistor? Carbon film, carbon comp, metal or doesn't it matter? How about the pot? .5, 1 or 2W? Carbon tracking?
Thanks again,
Roger
its basicaly a 69 spec with .1u in the output couplers. alway sbeen my fav spec too.rtcook wrote:Mark,
Well, we'll see if Larry chimes in on this.
I was just listening to your clip again. Amazing! I take it that is your 12000 series amp? I'm curious how this will work in my 69 setup. Not quite the same as the 12000 series. Which reminds me, I need to work on that amp, too. I have too many irons in the fire.
Roger
There's nearly no current flowing through the pot and through the resistor, therefore:rtcook wrote:Just to clarify, what is the minimun acceptable wattage for the 2.2M resistor? Carbon film, carbon comp, metal or doesn't it matter? How about the pot? .5, 1 or 2W? Carbon tracking?
interesting about the K2.novosibir wrote:There's nearly no current flowing through the pot and through the resistor, therefore:rtcook wrote:Just to clarify, what is the minimun acceptable wattage for the 2.2M resistor? Carbon film, carbon comp, metal or doesn't it matter? How about the pot? .5, 1 or 2W? Carbon tracking?
- for the resistors ones with a power capability of 1/8W are already overkill - and no matter which type. You can use CC's CF's or MF's
- for the pot the usual Mouser's with a power capability of .25W (log) or .5W (lin) also are plenty
And because we don't buildt HiFi equipment and even won't achieve the sterility of those, we may ignore a difference of the two sections of the pot up to about 10% - so if you got a 250K double pot with 235K/255K, no problem - it will work fine, because a certain imbalance is adding an extra amount of the harmonic K2 to the tone and makes it a tad juicier![]()
Larry
how about we call it "the based on Ken Fishers master volume type 2 that novosibir has been using in his builds for ever that rockstah discovered in the trainwreck pages in Gerald Webers book "a desktop reference of hip vintage guitar amps" that novosibir not only shared his wisdom to make this mod safe as well as supervised and made sure it was done right as rockstah installed it into his plexi build to discover it was the best master volume mod "rtcook wrote:Love this place! Just a wealth of information.
Thanks for the clarification Larry. I'm ready to incorporate this PPIMV (Larry's PPIMV or is it Mark's PPIMV?). How about the LarMar PPIMV?
Roger
