Output Coupling Caps and Bass response
novosibir
Re: Re:
Post by novosibir » Mon Jul 24, 2017 8:34 pm
FourT6and2 wrote:What about .047 PI output caps + a lower value for the bias resistors? Like 180K or 150K?
Why not?
FourT6and2 wrote:I know raising the PI caps increases bass response. But what does lowering the bias feed resistors do?
Cutting bass response, lowering PI gain
FourT6and2 wrote:I've never heard your Dino or British Purist amps.
Why not?
FourT6and2 wrote:How does the sound compare between .047/220K and .1/100K?
Try it, then you know it :D
Larry
FourT6and2
Re: Output Coupling Caps and Bass response
Post by FourT6and2 » Mon Jul 24, 2017 8:56 pm
Well, if halving the resistor value = raises -3dB corner freq. 1 octave... and doubling the cap value lowers the corner freq. 1 octave...
Then...
.1uF/100K and 0.047/220K will be about the same...
Except...
.1uF/100K = PI tube distorts a little less?
And the stock value of 0.022/220K and 0.047/100K are about the same, except again... in the second one, the PI tube is staying cleaner?
novosibir
Post by novosibir » Tue Jul 25, 2017 2:51 am
FourT6and2 wrote:Well, if halving the resistor value = raises -3dB corner freq. 1 octave... and doubling the cap value lowers the corner freq. 1 octave...
Then...
Except...
Exactly! Keep in mind, that the bias resistor has to be regarded in parallel to the plate resistor, so with a 100K bias R the gain of the PI is somewhat less than with a 220K bias R
FourT6and2
Post by FourT6and2 » Tue Jul 25, 2017 2:54 am
Then...
Except...
Is there a formula for calculating the difference in gain? How much "less" is "somewhat less"? haha!
If the PI stays a little cleaner, does that mean the the overall output of the amp decreases? Or do the power tubes then overdrive sooner?
novosibir
Post by novosibir » Tue Jul 25, 2017 3:24 am
FourT6and2 wrote:Is there a formula for calculating the difference in gain? How much "less" is "somewhat less"? haha!
https://www.ampbooks.com/mobile/amplifi ... alculator/
FourT6and2 wrote:If the PI stays a little cleaner, does that mean the the overall output of the amp decreases?
no
FourT6and2 wrote:Or do the power tubes then overdrive sooner?
they overdrive later
FourT6and2
Post by FourT6and2 » Tue Jul 25, 2017 11:38 am
thanks!
Post by Roe » Wed Jul 26, 2017 4:41 am
FourT6and2
Post by FourT6and2 » Wed Jul 26, 2017 11:33 am
Roe wrote:try this calculator instead:https://www.ampbooks.com/mobile/amplifi ... -response/
Yeah, I've been using all of the ones that site offers. The bone I have to pick with some of them (like the one you linked to) is you can't plot more than one line on the same graph. And every time it draws a new graph, it changes the scale. So you can't really compare back and forth. Its kind of annoying.
