Connecting the Lar/Mar in a Bugera 1960
- tshodges
Re: Connecting the Lar/Mar in a Bugera 1960
Can I cut the traces right at all Pin 5's?
If you are soldering the wires from the pot directly to the pins then yes you can cut the traces. Remember to have jumper to connect V4 and V5 grids and V6 and V7 grids together. If the bugera doesn't have, then it would be good if you also installed 5.6k swamp resistors directly on all power tube grids to avoid oscillation.
- tshodges
Awesome, everything should be done! I'll post pics shortly!
Definitely post some pics, this thread will be helpful to other people with the older bugera too.
Oh, and remember to take all the power tubes out before measuring. ALL pin 5s of the power tubes MUST have NEGATIVE dc voltage on them. If you don't get negative dc on all the grids don't put the power tubes in.
Where's the pics?
Good Questionplanetjimi wrote:Where's the pics?
Does ANYONE have pics of this connected to the pcb?
