Parallel effects loop for Marshall style amps
- novosibir
Icarus, when the loop section is after the Master and you crank the master, then "after the laws of physics" ALL after the master gets more juice - also your Send Level pot, also your Send jack!
Why do you wonder about this?
But OTOH I've never recommended, to place the loop section AFTER the Master! That's by your choice, if you like the sound colouration due to the 'afterburner effect' of the loop's recovery stage.
If not, and if you don't want to readjust your Send & Return pots after changing the output level via the Master, simply put the Master AFTER the loop section.
All might be so easy, if you only would imagine the signal flow through an amp. If you can't imagine the signal flow through an amp, better don't touch its inside and bring it to a good tech!
Larry
Larry
Ok thatnks for clearing this up.
I had to ask because the FX loop in my Plexi Reisse seems to distort the Rev/Delays when I turn up my (Standard Non PPIVM Master Volume)
And it sounds crap !
So im looking to put a better loop in my amp, to make the
Rev/delay/Chours FX sound Lush , not as if i am going through the front end of the amp.
Im not a tech , just a musician who has an great interest in amps
more than guitars these days.
So excuse my ignorance
Learning my way through reading through forums.
Marshall 1973 PTP
Marshall 1977 JMP 2204
Marshall Plexi Reissue
Marshall JCM 800 1959
Marshall 1982 JCM 800 2203
Mesa Boogie MKIV
Marshall 1960TV
2x12 V-30's
Eminar 4x12
2x12 Celestion Gh-80's
Mesa Boogie MKIV
Marshall 1960TV
2x12 V-30's
Eminar 4x12
- franc
I'm finally getting there
I had these cute chassis and boards made and I am deciding on where to put the holes to feed the wires into the main chassis.
I have already done the one for the heaters and thought about doing it like in the picture.
The pots are on the back to the left of the speakeroutputs so the wires are coming from there also.
Also, I am not sure whether I should create a grounding point inside the small chassis or feed a ground wire into the main chassis and connect it to the pots at the front or anywhere else.
Any thoughts?
Any thoughts?
- (75.25 KiB) Downloaded 950 times
- (59.53 KiB) Downloaded 953 times
- (64.56 KiB) Downloaded 952 times
Franc.
"I live my life like there's no tomorrow"
- novosibir
Ground the additional chassis ONLY to the amp's chassis simply by mounting it to it and ground the loop's layout inside the amp between the V2's and the PI's ground. Keep in mind, that you took the voltage supply from the PI's node, hence you'd have to ground the device 'in the right order' next to its ground point.franc wrote:Also, I am not sure whether I should create a grounding point inside the small chassis or feed a ground wire into the main chassis and connect it to the pots at the front or anywhere else.
Larry
- MacGaden
- Wiki Editor
- franc
Thanks Larry! Will do, I hope to report on the results very soon
Box was custom made by Ceriatone, most of my stuff comes from them (sorry George
importing from US is not very cost effective).
They also made me the boards (I had a batch of 10 made of both box and board).
Franc.
- Tuco
franc, it looks great, much better than my project box. Can I ask how much it cost? TIA.franc wrote:Thanks Larry! Will do, I hope to report on the results very soon
Box was custom made by Ceriatone, most of my stuff comes from them (sorry Georgeimporting from US is not very cost effective).
- franc
I had 10 of them made so they only cost something like 10USD each.
After drilling the top left hole for all the signal wires, I realised it is too close to the inputs. In fact, when I put in the grommet, there's no room for any wire at all because it touches the input
So I have to put it a bit closer to the hole for the heater wires.
Any problems in that?? Would it have been a good idea at all to have the signal wires that close to the inputs?
Franc.
- franc
This is what it's going to look like on the back of the amp.
Can't wait to hear this thing!
- (134.8 KiB) Downloaded 250 times
Franc.
- franc
I really could use some advice on the use of shielded wire.
I hate shielded wire, never really had better results with it
I have a wire from the input of the Send pot to the 820k resistor, which is going from the back of the amp where the controls are, through the top of the chassis, into the small chassis. Should I shield this?
Then there's a wire from the wiper of the Send pot, from the back of the amp, through the chassis, into the small chassis. What about that?
Another one, coming from inside the small chassis (.47u cap), through the top of the chassis, going to the Send input.... Shield?
Finally, a wire from the Return pot's wiper, through the top of the chassis into the small chassis....
Thing is, I can't really 'just try it out' because everything is under the main board, so if I have to change anything....
Franc.
- novosibir
Use RG174/U coax antenna cable as shielded wire, it has less than 100p/m (=30p/ft.) capacity conductor-shield, is flexible and small in diameter.
Larry
Larry
- franc
- MacGaden
- Wiki Editor
Is this the right stuff ? :novosibir wrote:Use RG174/U coax antenna cable as shielded wire, it has less than 100p/m (=30p/ft.) capacity conductor-shield, is flexible and small in diameter.
Larry
MacG.
- novosibir
Looks right!
When there's printed "RG174/U" anywhere onto the insulation, then it IS correct
Larry
Larry
