which version is this?novosibir wrote:In the version w/ true bypass switch are 2 2.2M resistors to avoid the switching pop.
Larry
Parallel effects loop for Marshall style amps
- rockstah
can u send me that schem - mark@markabrahamian.com - thanks
- novosibir
No, they are different animals!Ivabiggun wrote:... but does 2M2 mean 2.2uf's? What voltage do you reccomend?
2M2 is resistance, 2.2uF is capacitance.
Voltage rating for the 2M2 doesnt matter, all above 50v is ok.
Larry
- rockstah
- novosibir
Have you tried it or do you just guess?rockstah wrote:how does this loop work in a dimed plexi? it seems it wouldn't work that well and since its yours i figured you would know.![]()
Tell me one reason, why it shouldn't work well in a dimed Plexi!
Larry
All good questions!
I have a bare bones 100watt being slowly fleshed out on my bench in parallel with the 68 restoration.
I have put four preamp tube sockets in and cannot make my mind up whether to put the Bainzy mod as V0 or Larrys effects loop in as V4
I hate having my Electric mistress and DD3 in a front end loop
- rockstah
havnet tried it yet.. just wondering how it works in a dimed plexi. thats all.novosibir wrote:Have you tried it or do you just guess?rockstah wrote:how does this loop work in a dimed plexi? it seems it wouldn't work that well and since its yours i figured you would know.![]()
Larry
- jerrydyer
m
could i have noise problems if I am drawing my b+ from the wrong spot. I take it from the preamp 100k 100k juncture of the two first gain stages. thanx
vids.
- novosibir
I've never tried it, because it's simply wrong, to take it from V1
Larry
Larry
- Tuco
I have some noise in my loop in my JTM45, so I am re-routing some of the wiring. I am running the circuitry in a box on top, very similar to the box that Franc showed a couple of pages back. I have been running all the wiring into the amp chassis through two access holes. I will now expand that to four access holes: B+, heater wires, output to PI, and pot wires. My question is through which of these holes can I run all the loop's ground wires? Does it matter?
Also, can I do a star ground inside the loop box, and then run just a single ground wire into the amp chassis? If yes, can that star ground be attached to the loop box, or does this cause a bad ground loop?
TIA.
TIA.
- novosibir
Yes.Tuco wrote:Also, can I do a star ground inside the loop box, and then run just a single ground wire into the amp chassis?
Either the ground is on the box, but the box insulated from the chassis - or the box is grounded to the chassis and the circuit ground inside insulated from the box.Tuco wrote:If yes, can that star ground be attached to the loop box, or does this cause a bad ground loop?
But the box MUST have a grounding, otherwise it doesn't shield anything and your loop section will be noisy.
Larry
- Tuco
Larry, thanks.
What about my other question. If I have a star ground inside the box, I will have six wires entering the chassis through four access holes: ground, B+, PI input, 2 heaters, and pot wires. B+, heater, PI, and pot wires all get their own hole. Can I pair the ground wire with any of these without noise problems? TIA!
