5150, any luck with the scope? Did you try those shielded caps you mentioned? You guys try Larry's grounding suggestions/thicker wire?
Not yet for the scope test, caps are no where to be find for now, it is not a grounding issue, tried all of that with no improuvement.Froumy wrote: 5150, any luck with the scope? Did you try those shielded caps you mentioned? You guys try Larry's grounding suggestions/thicker wire?
Right! This is much more precise!5150loveeddie wrote:... I'm working on a probe to be able to bias direct from the plates and not the cathode, I know this is more dangerous or less safe to accomplish but it is much more presice, if this works I'll let you know. Those 1ohm resistors never are at 1ohm they all show around 1.4-1.6ohm, right there it won't work properly..
If they are 1% resistors, they are very likely to be actually extremely close to 1 ohm - within 1%, actually.5150loveeddie wrote:Those 1ohm resistors never are at 1ohm they all show around 1.4-1.6ohm, right there it won't work properly..
At first glance, er, listen, it sounds like crossover distortion to me, from too much drive to the output stage. This is very closely related to blocking distortion, except that blocking distortion usually refers to a type of distortion with a long time constant, where the entire signal cuts off, or is "blocked" for a period of time following a transient overload, resulting in a "farty" or "splatty" sound.Froumy wrote:Mr. Aiken,
Do you think these guys are experiencing crossover or blocking distortion? Thanks for all the great tech info that you've shared on your site! Very informative.
Which one?Billy Batz wrote:The reson it came out so clear and 'seperate' in that clip is I was using a MASS150. It does it horribly when I use that attenuator and set it low for some reason. What Im using now is a much superior attenuator and it sounds closer to how it does when unattenuated.
The MASS is a fully reactive load, which will greatly exaggerate the high-frequency content of the crossover distortion. You can see this on a scope if you compare the signal into a resistive load, like a Z airbrake, and the reactive load, like the MASS or Marshall PowerBrake.Billy Batz wrote:Great info. Thanks a million and I will try that.
What exactly would you do about it if this proves to be the cause? All my amps do this to some degree. Fenders and marshalls. It could be that I get it more then most people here because my cab is an H30-55 type while 90% of people here seem to use 25Wers. Also I assume attenuating may extend the speakers high end response since your running it much cleaner so that could factor in tho you can hear it unattenuated if you try real hard. If it depends on each OT that may explain why some amps do it more then others.
The reason it came out so clear and 'separate' in that clip is I was using a MASS150. It does it horribly when I use that attenuator and set it low for some reason. What I'm using now is a much superior attenuator and it sounds closer to how it does when unattenuated. Like ghosting. Back there somewhere but not so in your face.
If the PPIMV is implemented properly, there should be no increased crossover distortion when playing at levels below the point where the signal peaks hit zero volts at the output tube grids. The danger with most PPIMV implementations is that people run the wires too near other things which causes them to oscillate.Billy Batz wrote:There is a possibility thats it because one person has a PPIVMV and it didnt cure the problem when turned low. Im not sure if I tried to separate the grid wires from the plates more on V3. I may try that but I think I have. I think the grid resistor there is worth a try.
