novosibir wrote:Josh, you should be able, to simply imagine the Master pot after the Treble control and then instead of to go from the Treble's wiper into the loop section then go from the Master's wiper into it. If you can't imagine this, then I'm wondering, how you're able to buildt the loop section into your amp.
You are right, I have no idea what is going on. I will be having George build my 2203 clone later this year. Right now I've got a rear panel template in Corel Draw I'm messing with as I'll have to get a custom rear panel made. I'm also getting a custom chassis made.
Basically, I'm figuring out what extra holes I'll need to add for this loop. I'm also gathering this info, so I can tell George what to do when the time comes. I can't really read schematics too well, I do better with a mockup of the actual layout as it would look in the amp. But, I'm sure George will know what to do.
novosibir wrote:When you're using a relay for the DPDT loop bypass switch and a on-off-on toggle switch with the center pin to ground, then you may switch the relay on pos. 1 and the conjunction on pos. 3
I'm guessing a "relay for the DPDT loop bypass switch" and a "on-off-on toggle switch" you are talking about is the same thing? I read that to mean two seperate things, but I'm guessing you are just talking about me using ONE on-off-on DPDT toggle switch?
So, if I'm reading this right, I would be able to get the loop-on, loop-off, and loop-on with 820K/180K conjunction to ground on ONE on-off-on DPDT toggle switch?
I like this as I would much rather have one mini toggle switch sticking out the back of my amp vs. having two. So, right now I've got:
Send volume
Send jack
Return volume
Return jack
on-off-on DPDT mini switch
What brand parts do you like in this loop? I plan on using Vishay/Dale metal file resistors on the board of my amp, I'm guessing this would be good in the loop? And what brand/type caps do you like to use in the loop? I'll be using the IC MPP caps on my board, plus those few others you sent me.
