Which caps do I need for XXX model?
Post by VelvetGeorge » Tue Jan 11, 2005 5:57 pm
To help make it easier for those of you ordering board kits without siganl caps. Here are the values you'll need in Sozos or your brand of choice.
A .1uf presence cap is included for each model.
100 watt superlead '69 era circuit:
(1) .0022
(6) .022
(2) .1
(2) .68
100 watt superlead '68 era:
(7) .022
(2) .1
(1) .68 (2) for split cathode
100 watt Superbass (same as '67 SL):
(5) .022
(4) .1
50 watt models are the same as the 100's.
JTM 45 and Bluesbreaker:
(5) .022
(4) .1
Master Volume 100 and 50 watt:
(7) .022
(2) .1
(1) .68
rockstah
Post by rockstah » Fri Sep 23, 2005 3:28 am
thanks for the post George!
guitar007
Post by guitar007 » Mon Nov 14, 2005 9:51 pm
Yeah...thanks, VG! 8)
~guitar007
Bainzy
Post by Bainzy » Sun Apr 02, 2006 2:16 pm
Thought I might update this for people building other specs:
Ralle Spec:
(5) .022
(3) .1
(2) .68uf
****** EVH Spec:
(5) .022
(4) .1
(1).68uf (for the split cathode that the amp was changed to later)
Both these 2 specs need an additional electrolytic 330uF cap for the bypass cap on V2a Ck
I'll post some more as I think of them.
Shred Guitar
David_Well
Re: Which caps do I need for XXX model?
Post by David_Well » Sun Aug 16, 2009 10:49 pm
My 73 Super bass got a .68 in presence....
do you know why and
can we change the .1 for a .68?
flemingmras
Just out of curiosity...
Post by flemingmras » Fri Sep 04, 2009 5:45 am
...if people order caps for and install them in XXX model, will that make their amp "XXX" rated?
Or does that simply mean that they're ordering "brand X" caps?
Joshabr1
Post by Joshabr1 » Thu Sep 25, 2014 1:22 pm
David_Well wrote:My 73 Super bass got a .68 in presence....
do you know why and
The latter circuit was a 25k pot with the .68 and a 4k7 shunt resistor. The earlier circuit was a 5k pot with only the .1 cap. Some where shipped with a 5k pot and the 68/4k7 set up. If yours is like that u can simply switch to the .1 and have the old circuit. Which I like better.
Joshabr1
Post by Joshabr1 » Fri Dec 19, 2014 9:10 pm
I see u have 2 .68 caps on the 68 split cathode version. Was there a .68 across the v2 of many shared cathode amps???
