Xenrelic Luminary Overdrive Hi Gain Plexi Mod.
- xenrelic
Think For Yourself, Question Authority
Re: Xenrelic Luminary Overdrive Plexi Mod.
hi
the first link does not work.
i can't open it
Hot
i can't open it
Hot
LIFE IS TOO SHORT FOR A BAD TONE!!
- xenrelic
- xenrelic
Here's some pictures of my green 50watt head.
- axeman
- Riscchip
Re: Xenrelic Luminary Overdrive (1959 4 Gain Stage) Mod.
That's pretty cool, my friend. Thanks for sharing the layout and schematic.
That's one seriously loud looking head shell you've got there. Especially with the blue piping.
- xenrelic
nice tone man!!
Tubes???
Hot
Tubes???
Hot
Good stuff ... I'd like to try that eventually ... I've done simple mods to my amp but I'm still overwhelmed by some stuff so I hope you don't mind a couple of dumb questions:
- What is the principle behind this mod, in layman's terms (i.e. what are you cascading into what and how?). I'm trying to follow the schematic and a very brief description would help lots.
- What is different on this arrangement that would enable you to use an A/B box to switch inputs/channels? That idea really appeals to me. From the schematic it seems like the output of the "modern input" gain stage goes directly into the "vintage input", similar to the version of the "one wire mod" found here: http://forum.metroamp.com/viewtopic.php?f=4&t=23887" onclick="window.open(this.href);return false; but I've been told before that you can't A/B when doing that (??).
Many thanks!!!
Many thanks!!!
- novosibir
Correct, you can't A/B this! Either Vintage, or Modern input - like it's on all 2203/2204 MV Marshall'sShakkal wrote:... but I've been told before that you can't A/B when doing that (??).
Larry
Thanks Larry, clarification much appreciated.
- xenrelic
- axeman
Post a clip. The last one was very low, and I really want to hear you work.
I'd really like to hear this thing! Would you put up a clip? Pa pa pa palease?
- xenrelic
